IIRC (I may not!) there are no holes in the body where the other style clip is used. It is designed to fit in the trim, then the trim piece is pushed over the metal lip (part of the sheetmetal) and grips it by friction. The other trim piece has holes in the bodywork for the screws which the 'available' clips utilise.
In other words, if you want to use the repo clips in place of the 'grip' clips, you'll need to drill some holes.
It's a few years since I removed mine - but I'm pretty sure that is the case....
