Where can I find a fuse block? #1904637
09/02/15 01:15 AM
09/02/15 01:15 AM
Central Louisiana
jim Offline OP
jim  Offline OP
Central Louisiana
Friend has a '68 Dart and he had this fuse block burn up. He uses the car as a daily driver, so would like to get it fixed. He has the wires jumped out with in line fuse right now. Any help or suggestions is appreciated.
Re: Where can I find a fuse block? [Re: jim] #1904659
09/02/15 01:53 AM
09/02/15 01:53 AM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
Re: Where can I find a fuse block? [Re: Mr_fixit] #1904662
09/02/15 02:02 AM
09/02/15 02:02 AM
a universal fuse block from speedway mtrs would be an option (either way you have some soldering/crimping to do). What burned up the fuse block? www.classicindustries.com may have em or a local JY
Re: Where can I find a fuse block? [Re: RapidRobert] #1904677
09/02/15 02:45 AM
09/02/15 02:45 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
If they are the same as the 70 B body I've got one that's in really good shape. I cannibalized the harness of connectors. the print isn't as bright as that one but the body is excellent. PM if interested.
I’m listening.
Re: Where can I find a fuse block? [Re: RapidRobert] #1904682
09/02/15 02:55 AM
09/02/15 02:55 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
That's a corrosion issue. The clips are rusted which causes resistance and creates HEAT...
Re: Where can I find a fuse block? [Re: Jim_Lusk] #1904687
09/02/15 03:17 AM
09/02/15 03:17 AM
I had one that had that corrosion in the V clips & the ten dollar HF mini die grinder worked perfect to shine em up in minutes. EDIT HF 97626 on sale $9.99. on the back side you can drill out or uncrimp/remove terminals & resolder/recrimp as needed. I'm assuming the FB ain't burned up, just poor continuity
