Teflon Tape
#190447
01/11/09 12:26 PM
01/11/09 12:26 PM
Posts: 1,534 Florida
CHRGR69
Should it be used on brake line fittings?
Grandma always said I had "hands of gold"!
Re: Teflon Tape
[Re: CHRGR69]
#190450
01/11/09 12:35 PM
01/11/09 12:35 PM
RapidRobert
unlike NPT (pipe threads), inverted flare fittings seal where the concave surface of the flared brake line meets it's mirror image inside the female fitting, not on the threads. I do lube the threads on occaision for ease of tightening & applying a consistent amt of torque EDIT if you have a leak I'd suggest not cranking on the fitting but cut off the end &(carefully) reflare it.
Re: Teflon Tape
[Re: RapidRobert]
#190451
01/11/09 03:11 PM
01/11/09 03:11 PM
Posts: 15,489 the boonies
aarcuda
the boonies
Re: Teflon Tape
[Re: CHRGR69]
#190452
01/11/09 05:09 PM
01/11/09 05:09 PM
moparpollack
Lil Herman
Lil Herman
85086
No never but if you have a leaker try putting some antiseize on the treads. JohnRR gave me that tip and it cured my leaker right away.
