Dana 60 question #190343
01/11/09 10:16 AM
01/11/09 10:16 AM
oregon
savoyracer Offline OP
oregon
I have been running 4:56 gears in the car. i am going to a bigger motor now, and want to run 4:10 gears in the car. Was told that they are two different cases, and that I would have to install a spacer to run the 4:10's My question is this true? does the spacer take away from the strength? Does anyone make a 4:10 gear that will bolt in without the spacer? I do run a spool. thanks.....
Re: Dana 60 question [Re: savoyracer] #190344
01/11/09 10:27 AM
01/11/09 10:27 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Usually it's the other way around if I remember right, the big gear needs a spacer and the little gear doesn't.....but I think it depends on the brand of gear.
Mine was a factory 3 series carrier and had a spacer + 4.88s in it when I got it, I took the spacer off and put 4.10s on the same carrier.
Rich H.
Esse Quam Videri
Re: Dana 60 question [Re: ZIPPY] #190345
01/11/09 10:35 AM
01/11/09 10:35 AM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
There are 2 different carriers one for 4.56+ and one for 4.30- you cant use the 4.88 carrier with a 4.10 gear. The spacer is for using a 4.56 gear on a 4.10 carrier. John spacer
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Dana 60 question [Re: savoyracer] #190346
01/11/09 01:17 PM
01/11/09 01:17 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I'm pretty sure that Richmond gear 4.10 street gear and pro gear are both for a 4.56-up carrier.
Re: Dana 60 question [Re: Mopar_racer_99] #190347
01/11/09 01:26 PM
01/11/09 01:26 PM
No. cal., sacramento usa
speedy383 Offline
speedy383  Offline
I am considering the same . Strange lists a 4.10part #69-0052-1 for a 4.56 up carrier without a mention of a spacer, and a pro gear#79-0011-1 for a 4 series carrier,. Are these newer parts ,i dont recall these being available ahout a year ago.
Re: Dana 60 question [Re: 446acuda] #190348
01/11/09 01:42 PM
01/11/09 01:42 PM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Dana 60 question [Re: Triple Threat] #190349
01/11/09 04:12 PM
01/11/09 04:12 PM
You need spacer on the 3 series carrier to run 4.56 to 5.86 gears, reason being the pinion is smaller and ring gear must be moved over...I did hear that they made a 4.10 for the 4 series carrier,,,The ring gear is thinner..I don't recommend using the spacer, I broke the ring gear bolts a number of times in my stocker with 9" slicks, 5.13 gears..Went to 4 series carrier never broke it again..
Re: Dana 60 question #190350
01/11/09 05:12 PM
01/11/09 05:12 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I ran 4:88's with a spacer for years without the ring gear loosening up. Changed to 4:56 didn't need the spacer.So that would tell me you wouldn't need a spacer for 4:10"s
Re: Dana 60 question [Re: rowin4] #190351
01/11/09 08:24 PM
01/11/09 08:24 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use the spacers all the time with no problems.There are 2 different carriers as well as thick and thin ring gears.
