2003 odge neon wiper issue
#1903460
08/31/15 09:16 PM
08/31/15 09:16 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
When the car is not running I can turn the ignition switch to "on" and the wipers work normally, on, off, delay... If I start the engine, wipers run all the time and will not turn off. Get this... If I step on the brake the wipers stop. If I let go the brake the wipers start going again. Does anyone have any idea what could be causing this?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 2003 odge neon wiper issue
[Re: W.I.N. Racing]
#1904078
09/01/15 02:23 PM
09/01/15 02:23 PM
Posts: 5,777 ohio
ruderunner
ohio
Bad ground somewhere. Look close at wiring near the battery.
Angry white pureblood male
[Re: W.I.N. Racing]
#1904589
09/02/15 12:01 AM
09/02/15 12:01 AM
W.I.N. Racing
Byron, NY
The answer is... a bad (shorted)washer pump motor and multi function switch(stuck on wash). I got ahold of a wiring diag and started pining things out and found (at the switch) power going to the washer pump but the pump was not running, so I unplugged the pump and voila...issue gone.
