Re: Dana 60 question
[Re: savoyracer]
#190344
01/11/09 10:27 AM
01/11/09 10:27 AM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
Usually it's the other way around if I remember right, the big gear needs a spacer and the little gear doesn't.....but I think it depends on the brand of gear.
Mine was a factory 3 series carrier and had a spacer + 4.88s in it when I got it, I took the spacer off and put 4.10s on the same carrier.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#190345
01/11/09 10:35 AM
01/11/09 10:35 AM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
There are 2 different carriers one for 4.56+ and one for 4.30- you cant use the 4.88 carrier with a 4.10 gear. The spacer is for using a 4.56 gear on a 4.10 carrier. John spacer
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
[Re: Triple Threat]
#190349
01/11/09 04:12 PM
01/11/09 04:12 PM
You need spacer on the 3 series carrier to run 4.56 to 5.86 gears, reason being the pinion is smaller and ring gear must be moved over...I did hear that they made a 4.10 for the 4 series carrier,,,The ring gear is thinner..I don't recommend using the spacer, I broke the ring gear bolts a number of times in my stocker with 9" slicks, 5.13 gears..Went to 4 series carrier never broke it again..
