So the stall converter won't be terrible without a fairly big camshaft?
Have you ever tried to port a head... if you can clean
up the bowls that helps a lot.. pretty simple and minimal
amount of tools... and thats where the biggest bang for
the buck is... have the heads had a valve job done on them
yet.. I always start with a strong bottom end... its easier
to change a set of heads or intake than it is to pull the
engine
EDIT
a higher stall conv can deal with a small cam but a
low stall hates a big cam.. big cam and a low stall
is a MUTT off the line till you get the rpm up to the
torque rpm
