brake pedal reinforcement bracket 69 B-Body #1902678
08/30/15 09:11 PM
08/30/15 09:11 PM
bethlehem pa
mikemee1331 Offline OP
bethlehem pa
how much of a bear is it to remove? i'm referring to the plate in the engine bay that the master cylinder is bolted to. my wiring bracket that mounts behind it is broken and i need to replace my master cylinder so.....
and what color? Google is not my friend on this as i'm seeing a lot black and some body color.
Re: brake pedal reinforcement bracket 69 B-Body [Re: mikemee1331] #1902844
08/31/15 12:03 AM
08/31/15 12:03 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Pulled mine off with a varying selection of 1/4" extensions to get past the steering column bracketry. A little time on your back but not a hard job.
ALL the plates I've seen were black that were off of original cars. Body color is when the person doing a repaint doesn't mask it off or pull it.
Re: brake pedal reinforcement bracket 69 B-Body [Re: mikemee1331] #1902850
08/31/15 12:13 AM
08/31/15 12:13 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yup, all were black. Is your's manual or power? Regardless, there are some nuts that have to be removed inside the car. A long extension and deep socket does the trick. You should take the pushrod bolt out of the brake pedal so the pushrod comes out with the master or booster.
Re: brake pedal reinforcement bracket 69 B-Body [Re: Dean_Kuzluzski] #1906361
09/04/15 03:28 PM
09/04/15 03:28 PM
bethlehem pa
bethlehem pa
i beg to differ on this statement! GOOD LORD! the right side was a total PITA! i'm thinking that side doesn't really need that nut when it goes back on!
Re: brake pedal reinforcement bracket 69 B-Body [Re: mikemee1331] #1906378
09/04/15 04:05 PM
09/04/15 04:05 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
LOL... My opinion is the older you get the harder this job is.. At 60 yrs old, I take out the interior, well I guess I should say I "have to " take out the interior.... LOL again...
Re: brake pedal reinforcement bracket 69 B-Body [Re: mikemee1331] #1906388
09/04/15 04:41 PM
09/04/15 04:41 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
These days, just getting under the dash is hard work!
If you don't put that nut back on, your going to have a new rattle. Chrysler didn't spend the money to put it there unless they needed to. Gene
Re: brake pedal reinforcement bracket 69 B-Body [Re: poorboy] #1906411
09/04/15 05:11 PM
09/04/15 05:11 PM
bethlehem pa
bethlehem pa
and a guilty conscience!
i'm gonna try with a long magnet. if not, i'll pack the stud with foam.
not that i would notice yet another rattle........
