Re: Tunnel Ram starting when cold??
[Re: Hyper Henry]
#1902366
08/30/15 12:06 PM
08/30/15 12:06 PM
Posts: 250 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
i turn my electric fuel pump on, 2 pumps of the throttle and turn key. it fires up instantly. I've never had a problem starting with a tunnel ram.
i don't know how it's different then a single carb?
[Re: 79410aspenrt]
#1902372
08/30/15 12:14 PM
08/30/15 12:14 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
i turn my electric fuel pump on, 2 pumps of the throttle and turn key. it fires up instantly. I've never had a problem starting with a tunnel ram. THIS^^^ But try turning off your fuel pump and then hit the key, once you're running turn fuel pump back on. I bet your floats are too high. Set floats where fuel barely trickles out of site port or glass.
[Re: Hyper Henry]
#1902402
08/30/15 01:13 PM
08/30/15 01:13 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Originally Posted By 79410aspenrt i turn my electric fuel pump on, 2 pumps of the throttle and turn key. it fires up instantly. I've never had a problem starting with a tunnel ram.
THIS^^^ But try turning off your fuel pump and then hit the key, once you're running turn fuel pump back on. I bet your floats are too high. Set floats where fuel barely trickles out of site port or glass. Two pumps, start the mator then turn on the pump.
[Re: Hyper Henry]
#1902420
08/30/15 01:41 PM
08/30/15 01:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
First of all.. see if your carbs are bleeding down.. you might have a pile of fuel in there so you wouldnt have to touch the throttle
[Re: Hyper Henry]
#1902536
08/30/15 05:26 PM
08/30/15 05:26 PM
Posts: 31,027 Oregon
AndyF
How cold is cold? I have a heated shop so my stuff is never colder than 60 degrees and it fires right up.
Years ago I lived in north Idaho and didn't have a garage. My Max Wedge Dodge was the only car that I had so I had to start it dead cold during the winter months. That was a real chore. Lots of choke and some starter fluid was usually required.
Once I upgraded to a heated garage my cold start problems went away! (I also used a block heater for a few years and that worked fine. Plug the block heater in an hour before you need to start the car and it fires right off.)
[Re: Hyper Henry]
#1902668
08/30/15 08:55 PM
08/30/15 08:55 PM
79410aspenrt
Saskatchewan (SK)
this is my exact procedure every time,
turn fuel pump on (3-4 seconds), turn fuel pump off, 2 pumps of throttle, turn key and it fires instantly. turn fuel pump back on. I've never had a problem in cold weather.
no spitting back through carbs, just idles nice. no chock
[Re: Jeremiah]
#1902685
08/30/15 09:18 PM
08/30/15 09:18 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
How big are the accelerator pumps?
I'd think that a tunnel ram would like more fuel to start than less due to the plenum volume being so much larger. When you pump it twice and light it up what happens? Does it spit through the carbs?
Do you have the start and run circuits on the starter switch tied together to power the ignition box? I have seen several cars that had power to the ignition in "run" or "on" but not during cranking. The car would foul the plugs unless you gave it ether(in any weather conditions) and then it would start about 70-0% of the time. It took me a while to wrap my mind around that one...after changing out ignition boxes, distributors, carburetors, etc. I had a buddy with a 440 tunnel ram, he had it setup so he would crank then hit the ignition, bam it would fire. This was a street car that he drove three seasons in north Iowa, I have seen him start his charager at 45 degrees cold. It was also the best running street tunnel ram I've ever seen.
Have a great day Iowan
"obsolete is neat"
[Re: Hyper Henry]
#1902738
08/30/15 10:28 PM
08/30/15 10:28 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
annular discharge boosters?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: quickd100]
#1902823
08/30/15 11:42 PM
08/30/15 11:42 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Our tunnel ram if anything starts better cold than warm. That situation has improved overtime. I have worked on the carbs quite a bit, lowered the idle feed jets in the blocks, reduced the size of the jets and air correctors etc. Made sure the carbs were the same, counted the idle speed screw turns etc. Anyway, basic procedure is to turn key to start, let it crank a second or two, if that does not do it a pump or two with a little bit of throttle cracked and it lights off. It actually should need a little bit of accelerator pump cold as the idle mixture should be set up for a warm engine. This assumes no cold start features of course. We have a 452 with Weiand tunnel ram and 2 x Holley 600 Ultra carbs. Have also worked on the distributor making sure the air gap was correct. My guess is you are rich, what size idle jets and air correctors are installed? Check out http://racingfuelsystems.myfunforum.org/index.php for lots of good carb information. Good luck. Best regards, Dave
