Puzzling ignition issue #1901885
08/29/15 03:54 PM
08/29/15 03:54 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
When are car stays hooked it revs to 4500 and then starts to babble and wont rev any higher. If it spins it will still babble between 4500-5000 then clears up and pull clean to 7000 rpm. Msd digital box 7535 with there hvc coil. 540 hemi with f3 procharger. Have changed cap rotor and coil looking at box or wires next. Any input would be greatly appreciated.
Re: Puzzling ignition issue [Re: nitrousr] #1901894
08/29/15 04:04 PM
08/29/15 04:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you carb or injected.... if injected what does the
O2 tell you.. whats the plug gap
wave
Re: Puzzling ignition issue [Re: nitrousr] #1901902
08/29/15 04:26 PM
08/29/15 04:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
If you're sure it's ignition, I would check rotor phasing. I know I sound like a broken record on that point, but with small caps, boost referenced timing and high cylinder pressure, you have to get phasing correct. Phasing at peak cylinder fill when cylinder pressure is the highest(peak TQ) is a must.
Re: Puzzling ignition issue [Re: TRENDZ] #1901909
08/29/15 04:37 PM
08/29/15 04:37 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
Plug gap is at .018, its a carburated deal. Will have to check rotor phasing the weird part is once it clears up it pulls clean the rest of the way and we are going thru the end at almost 33 pounds of boost which in my mind would put more stress on the spark. Is it possible we are pulling too much timing too quick? Its set at 35* then at 3 pounds it pulls 17* out.
Re: Puzzling ignition issue [Re: nitrousr] #1901934
08/29/15 05:33 PM
08/29/15 05:33 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Why the big step in the timing? Are you running a map, or pressure sensor? I would think you would get a much more even timing curve with load based timing. Maybe I'm not understanding what your set up is.
Re: Puzzling ignition issue [Re: nitrousr] #1901940
08/29/15 05:44 PM
08/29/15 05:44 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
This is a generalization, but I would pull about .8 degrees pr lb of boost. That was with 93 ethanol pump gas.
So, set up the timing curve like you would a N/A engine and remove timing in direct relation to boost pressure. If the timing at atmospheric pressure is 35, then at 3 lbs of boost the timing would be 32.6.
Re: Puzzling ignition issue [Re: TRENDZ] #1901944
08/29/15 05:50 PM
08/29/15 05:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'll ask ...if the timing drop is at the same rpm..
in other words.. is that rpm when you hit 3 psi and
drops timing... that is a big drop
wave
Re: Puzzling ignition issue [Re: MR_P_BODY] #1901985
08/29/15 06:59 PM
08/29/15 06:59 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
The only reason i can give for the big drop is its a 35 for driving around on the street and 18* was a safe tune on the dyno. We have the msd map sensor on it.
Re: Puzzling ignition issue [Re: nitrousr] #1901989
08/29/15 07:02 PM
08/29/15 07:02 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
Mr P i think i get where you are going here, right now its set up to go straight to 18* once the boost starts. But maybe a more gradual curve of timing versus boost?
Re: Puzzling ignition issue [Re: nitrousr] #1901992
08/29/15 07:04 PM
08/29/15 07:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
It's the tune up. The difference in hooking or not, is because it changes the load on the motor. The fuel curve through that area, with the timing that low is not right............sounds rich to me
Re: Puzzling ignition issue [Re: nitrousr] #1901993
08/29/15 07:05 PM
08/29/15 07:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thats my thinking... have it follow the boost... is
the point where it babbles at the timing drop
wave
Re: Puzzling ignition issue [Re: nitrousr] #1902010
08/29/15 07:28 PM
08/29/15 07:28 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You should have the 3 bar map on it. All your timing should be load/rpm based. Cruising around will want more than 35 degrees in certain situations, and less in others. Smooth transitions in the whole table. I believe msd allows for a 45 degree sweep.
Re: Puzzling ignition issue [Re: Monte_Smith] #1902017
08/29/15 07:38 PM
08/29/15 07:38 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
Appreciate all the input, Mr Smith do you think being more aggressive timing curve this by increasing the load on the motor?
Re: Puzzling ignition issue [Re: nitrousr] #1902019
08/29/15 07:47 PM
08/29/15 07:47 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
Mr P I would think the timing drop is right before the babble starts. We do have the 45 sensor on. And double checked the box had the right sensor entered just in case.
Re: Puzzling ignition issue [Re: nitrousr] #1902640
08/30/15 08:27 PM
08/30/15 08:27 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
This is a sample of a decent timing curve for a 2 bar/ sbc. Get the timing curve corrected, then get after the fuel. It is only here to show the smoothness of the timing, and the range at different loads. Don't use these specific numbers as they are not intended for any motor but the one they were wrote for.
If your engine rpm wont increase, it's because the engine load is higher than the engine power. You have a big blown hemi, you should have enough power, so your tune up has to be WAY off. Your timing curve is way out of wack, and most likely, the carb has a hard time transitioning from low boost to high boost. You are likely flooding, and retarding the engine at that part of the engines range.
With tire spin, the engine can zing right through the bad section of the tune.
Re: Puzzling ignition issue [Re: TRENDZ] #1902656
08/30/15 08:46 PM
08/30/15 08:46 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
Cool stuff, appreciate the help.
Re: Puzzling ignition issue [Re: TRENDZ] #1902666
08/30/15 08:52 PM
08/30/15 08:52 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What octane fuel are you using with that boost level??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Puzzling ignition issue [Re: hemi-itis] #1902682
08/30/15 09:17 PM
08/30/15 09:17 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
C-16, plan was to run 23-25 pounds but due to a shorter tire being used rpm/boost is alot higher than anticipated.
Re: Puzzling ignition issue [Re: nitrousr] #1905435
09/03/15 01:13 AM
09/03/15 01:13 AM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
If the rich condition was caused by timing would it still produce the black smoke usually associated with too much fuel?
Re: Puzzling ignition issue [Re: nitrousr] #1905445
09/03/15 01:25 AM
09/03/15 01:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure if its not burning it... with that fuel its slow
burning and would like the timing... just get a good
curve on it
wave
