451 Build
#1900602
08/27/15 07:51 PM
08/27/15 07:51 PM
Posts: 7 Michigan
LOtownNate
First time building an American V8. Want some opinions on what I have and maybe a guess on how much power it will make.Thanks
CP Flat top pistons Indy EZ (full cnc MW size by MCH) Indy single plane manifold 1.6 ratio rockers Lunati solid roller (specs are 1.5 ratio) Advertised Duration (Int/Exh): 279/285 Duration @ .050 (Int/Exh): 249/255 Gross Valve Lift (Int/Exh): .585/.600 LSA/ICL: 110/106 Holley 950
Re: 451 Build
[Re: LOtownNate]
#1900733
08/27/15 11:16 PM
08/27/15 11:16 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I agree with Andy, you need a lot more cam to use the heads you have on a small motor. That will need to spin to make some power.
Re: 451 Build
[Re: LOtownNate]
#1900795
08/28/15 12:33 AM
08/28/15 12:33 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
Is this a B or RB block build What is the lobe lift and valve lash settings for the cam? I like and use as much rocker ratio that I can get away with on the cams I pick now The 1.6 ratio will make your cam have more duration and lift from the opening to the closing and it will open the valve further and quicker at the same time
Re: 451 Build
[Re: AndyF]
#1908734
09/08/15 05:04 PM
09/08/15 05:04 PM
BradH
Ah okay, solid roller cam, good heads, 451 inches, E body car with 4.10 gears and street/strip. Hmmm... sounds familiar. MW heads are too big for that displacement and will kill the torque curve under 5K. If Trick Flow would get off their corporate a$$ and get the new PowerPort 240s into the publics' hands, I'd say that's what you'd want to run. With better suited heads and a cam in the range that's been thrown around (255-260-ish at .050"), you'll still need a converter w/ a flash around 4200-4500 to launch hard, which will require really sticky DOT tires or slicks, and suspension updates, and... Oh, crap, this is how it all starts.
