Re: 383 fresh air cleaner/pcv
[Re: Jim_Lusk]
#1900213
08/27/15 04:51 AM
08/27/15 04:51 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
Pcv goes to the carb, not the air cleaner... ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) The PCV hose shuld go to the back of the carb. so it sees manifold vacume all the time, that is the only way it will pull a vacume through the motor ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) The air inlet hose to the valve covers from te air cleaner on stock Mopars don't have a filter, shame on Ma Mopar for not running that hose to the inside of the air cleaner for filtered air ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif)
