Re: 383 fresh air cleaner/pcv
[Re: Jim_Lusk]
#1900213
08/27/15 04:51 AM
08/27/15 04:51 AM
Posts: 43,274 Bend,OR USA
Cab_Burge
Pcv goes to the carb, not the air cleaner... The PCV hose shuld go to the back of the carb. so it sees manifold vacume all the time, that is the only way it will pull a vacume through the motor The air inlet hose to the valve covers from te air cleaner on stock Mopars don't have a filter, shame on Ma Mopar for not running that hose to the inside of the air cleaner for filtered air
