Re: nitrous line repair?
[Re: 70satelliteguy]
#1900514
08/27/15 05:17 PM
08/27/15 05:17 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
Yes, you can have a hydraulic repair shop cut off your old hose end and crimp on a new one. I went to 2 hydraulic shops here...one won't touch nitrous lines, said he can't guarantee his end will hold the pressure. The other said no problem. I had a couple of long lines that had bad places in them that leaked. I cut out the bad sections, had new ends crimped on, now have some short hoses I use to fill bottles with. I know several guys that use hoses on their race cars w/ ends crimped on by the same shop.
You can't use a regular hose end like you do for your AN fuel lines. Those will not stand the pressure and blow off.
#1900535
08/27/15 05:38 PM
08/27/15 05:38 PM
Challenger 1
Cincinnati, Ohio
Does someone make a do it yourself repair kit for these lines? Mike Yes they do, plenty of field install-able steel ends. I have made plenty of them and even tested them to per the NHRA rules. I used the same fittings and hose to custom make all my brake lines on 265 mph dragsters. I have done some 6 second in the 1/4 mile nitrous racing in a dragster and used plenty on nitrous over the years. Used that stuff on the street too. I installed it on many street cars for friends and customers and made most of the lines myself.
[Re: Challenger 1]
#1900537
08/27/15 05:42 PM
08/27/15 05:42 PM
Challenger 1
Cincinnati, Ohio
All my fittings are at my race shop, pictures later on. It's either a #3 or #4 hose and here's the ends from Summit. I also make CO2 hose out this same hose and fittings as WE fill CO2 and nitrous tanks at work. I make all of our hoses for the most part. Link
#1900554
08/27/15 06:11 PM
08/27/15 06:11 PM
Challenger 1
Cincinnati, Ohio
"Yes they do, plenty of field install-able steel ends" Thanks Challenger for the reply. Is there a company that I can order one from? Do you have a link that you can post? Thanks MIke
Sure checkout my post above with a Link to Summit Racing. Bragging, checkout this blurry picture of a picture of my old dragster I built around 1991. I made every hose on the car, it was injected on methanol, nitrous injected with gasoline and a 4 stage dry sump for the oiling. Not my fastest car, not even close but it had the most hoses on it and I engineered everything to fit in a dragster. It had a belt driven fuel pump on the front of the motor. BTW it was a 632" aluminum dovovan block, pontiac big chief heads and about 500HP of nitrous on it with a progressive controller for the nitrous. It went high 6s.
[Re: Challenger 1]
#1900564
08/27/15 06:28 PM
08/27/15 06:28 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Wow that is a lot of lines and solenoids!! Challenger my nitrous FEED line is .425 OD.I have the Big shot kit.I think that is a -6? The link refers to a -3. I am guessing that it the line from the solenoid to the carb base? Are -6's available? Thanks MIke
#1900983
08/28/15 11:30 AM
08/28/15 11:30 AM
an8sec70cuda
Those Aeroquip PTFE fittings use a 45° flare. AN fittings are 37°...make sure you're getting the right stuff.
[Re: an8sec70cuda]
#1901005
08/28/15 11:57 AM
08/28/15 11:57 AM
Challenger 1
Cincinnati, Ohio
Those Aeroquip PTFE fittings use a 45° flare. AN fittings are 37°...make sure you're getting the right stuff. Hydraulic/high pressure lines use 45° fittings.
#1901018
08/28/15 12:15 PM
08/28/15 12:15 PM
an8sec70cuda
Yes, but the nitrous AN lines are 37° aren't they? All AN fittings are 37°. The bottle nuts, fittings to the solenoids, etc. all should be 37° correct? I'm assuming when you buy a -6 AN nitrous feed line that the hose ends have 37° flares...which is what he has. If he's getting ready to put a 45° hose end where a 37° end was w/o changing his other fitting on the bottle to 45°, he's going to have a leak.
#1901221
08/28/15 05:34 PM
08/28/15 05:34 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
This may sound wacky, but some fitting manufacturers use a multi angle seat. Think of the female part of the fitting like a serti valve job. A rounded area in the center of the sealing area covers both angles with one part number.
