Re: 74 d100 disc brakes
[Re: mgoblue9798]
#1900110
08/27/15 12:29 AM
08/27/15 12:29 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Long ago I had a 1974 D100 and as I remember the brakes were essentially the same that you would find on a C-Body of similar vintage. The simplest improvement that you could make would be to get some new stock rotors for the front and new drums for the rear. Shop for those on www.rockauto.com and while you are at it get the premium brake pads and shoes. I put on some 15x7 Cop Car wheels with 255/70R15 tires and I never had a problem stopping
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: mgoblue9798]
#1903203
08/31/15 03:42 PM
08/31/15 03:42 PM
Posts: 1,153 Cruising!
QuickDodge
Cruising!
Why do you want to upgrade the brakes? Are you planning on towing, racing, or ????
To my knowledge, the only factory upgrade for the brakes is to swap on the brakes from a 3/4 or 1 ton truck. I think the heavier duty trucks had rotors 1 inch larger in diameter. There are several potential problems though: First, the one ton rotors weigh more. If you are thinking of a racing / high performance application, these may be to heavy. If you want larger brakes because you are towing or hauling heavy loads, the brakes off the heavy duty pick-ups are ideal. Secondly, the heavier duty trucks had 8 lug wheels instead of 5 lug wheels. You will have to buy new wheels and possibly tires with the switch to 8 lug wheels. If you convert the front end to 8 lug wheels, you will probably want to swap in an 8 lug Dana 60 or 70 rear axle so the wheels match on the front and rear of the truck. That way you will only need one spare tire. The master cylinder and brake booster are probably different between the 1/2 ton and heavier trucks as well.
Most guys are satisfied with the factory brakes on the 1/2 ton trucks. These were decent brakes for their era. Are you sure the brakes on your truck are functioning properly?
[Re: QuickDodge]
#1904656
09/02/15 01:47 AM
09/02/15 01:47 AM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
I wondered if some like large diameter modern brakes is what your after? Like a corvette type swap? Some people treat their truck like cars with 18" rims or so and want to fill in the space. A custom spindle and ingenuity? I lack skills for the latter.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
