Vibration in power steering wheel only turning 1 way - box? #1899541
08/26/15 01:40 AM
08/26/15 01:40 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Hello,
After our '67 300 is driven for a while it seems that the power steering causes a vibration when turning the wheel right. I assume this issue is in the box due to it only being in one direction. My plan is to replace or rebuild the box. Is there anything I can check prior to pulling everything apart?
Thanks!
Re: Vibration in power steering wheel only turning 1 way - box? [Re: Jeremiah] #1899550
08/26/15 01:59 AM
08/26/15 01:59 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I have had "pulsating" feeling steering issues appear when turning in one direction 2 times in the past. Once was an outer tie rod falling apart and the other time the power steering belt was a little too loose. The loose belt only pulsated when turning left for some reason and never made any noise like you would expect a loose belt to.
Check the dumb simple stuff first before buying a new box or pump.
Re: Vibration in power steering wheel only turning 1 way - box? [Re: Neil] #1900191
08/27/15 03:01 AM
08/27/15 03:01 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thanks, I'll pull the front wheels off and have a look this weekend.
