HELP needed
#1898344
08/24/15 02:51 PM
08/24/15 02:51 PM
Posts: 806 Kentuckian
sixpakx
Kentuckian
sorry so long, not as sharp as i use to be, my son n law bought a 71 rr 383, big big can and no coverter(dies when put in gear)heads shaved with shims under rockers, so we ordered a 284 cam, bought a set of rebuit 906 heads from indy( i know).yesterday i took it apart and sure enough shimmed, pass side rocker shaft holes was at the top(upside down), and i noticed 15 0f the push rods have holes thru them like chevys, motor was very clean, got it back together and set the rpm,s @ 3500 for 15 minutes, then dropped it to 950. noticed it had 10 psi oil pressure(aftermarket mech gauge) don,t know what it was before we took it apart, racing eng it moves very little, would these open push rods cause this? and what kelp it from blowing up? i,ve only saw solid push rods in stock eng, again sorry but any help needed
Re: HELP needed
[Re: sixpakx]
#1898618
08/24/15 09:26 PM
08/24/15 09:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Unless the lifters have oiling holes too, then it's not an issue.
If the lifters do, then possibly that is your issue. 10 Psi is on the low side, but still above spec, barely. What weight oil are you running?
I prefer to run 10w30 myself.
Re: HELP needed
[Re: sixpakx]
#1898780
08/25/15 12:51 AM
08/25/15 12:51 AM
Supercuda
About to go away
About to go away
up yours
At 20w50 I'd expect to see more pressure at idle, unless you have some real loose bearing clearances. Sorry I can't offer more.
Re: HELP needed
[Re: sixpakx]
#1898957
08/25/15 11:59 AM
08/25/15 11:59 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Start the engine again. Does the oil pressure go up with rpm?
If so, hop in and hit the road.
If not, dig into it to find the problem.
Re: HELP needed
[Re: sixpakx]
#1899000
08/25/15 01:06 PM
08/25/15 01:06 PM
RapidRobert
What Feets said & 15 (confirmed with a good gauge) ain't gonna cut it. not sure where the prob is but I would definitely dig in. not sure if the additional flow from the oil thru pushrods is the cause or not (I'm thinking not) but that (might) be the first thing I'd swap & check further on that situation (& check preload while you are at it but that is unrelated to the psi).
