Driveshafts: Steel vs. Aluminum vs. Carbon Fiber #1897930
08/23/15 09:55 PM
08/23/15 09:55 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
I have an upgraded HD steel driveshaft in my 'Cuda now, built back in the '80's. All made before the advent of aluminum or carbon fiber. I am guessing that the lesser weight of these would make the car et faster. Anyone have any idea how much better a car will perform with either of these 2 materials? Do they hold up as well as steel? Are they safer/stronger than steel? Are they worth the expense?
[image][/image]
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1897992
08/23/15 10:58 PM
08/23/15 10:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Reduces the ET by .000 RCH
Boffin Emeritus
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: polyspheric] #1897995
08/23/15 11:02 PM
08/23/15 11:02 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Does that prediction also account for a lighter weight wallet with the non steel DS?
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: polyspheric] #1898006
08/23/15 11:15 PM
08/23/15 11:15 PM
sgcuda Offline OP
sgcuda  Offline OP
What is RCH? Why wouldn't et lower if reciprocating weight is reduced?
[image][/image]
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898021
08/23/15 11:35 PM
08/23/15 11:35 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
You are asking a question discussed many times before. Usually no one has any real proof to support a performance increase. You are correct, it has to be an improvement, but evidently not enough to notice. Just the weight savings, should be a plus.One thing is the high dollar items can be thought to be better built/higher quality, and built the next size larger dia, which is a huge improvement in increasing the shafts "critical speed" ( jump ropes). I have a few Alum Glued MW shafts, and if money was not a big concern, I would go CF, which when it fails, has a lot less destructive energy to deal with and becomes flexible strands/fibers, FWIW. bump
PS, "is it worth it dollar wise?" Only one person can answer that.
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898106
08/24/15 01:02 AM
08/24/15 01:02 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The carbon shaft won't damage the car when it breaks. Steel and even aluminum will both beat your car all to hell underneath
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: jcc] #1898140
08/24/15 02:51 AM
08/24/15 02:51 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Years ago when nascar started wheel dyno'ing the cars after the races and they noticed it. I know people on a craftsman truck team back then that tested small diameter driveshafts vs heavier and larger diameter driveshafts.
They claimed the smaller diameter would whip, which consumes energy, which consumes horsepower. Makes sense.
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898268
08/24/15 12:36 PM
08/24/15 12:36 PM
New York
polyspheric Offline
polyspheric  Offline
New York
It's not reciprocating weight.
Boffin Emeritus
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898284
08/24/15 01:02 PM
08/24/15 01:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being close to center line it just comes down to the
weight... and the cost.. I just use DOM
wave
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898323
08/24/15 02:19 PM
08/24/15 02:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Carbon shafts are marginal lighter than aluminum for sure. But as Monte pointed out the shatter and splinter when they break, unlike aluminum and steel. All the materials have a different critical speed. Diameter, material type and length will determine what material is necessary to avoid reaching a given materials critical driveshaft speed and keeping it from "whipping" the driveshaft on track.
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: Al_Alguire] #1898329
08/24/15 02:26 PM
08/24/15 02:26 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Years ago my buddy tore up a CF drive shaft. He put his steel one back in, and made no difference in ET.
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898596
08/24/15 08:59 PM
08/24/15 08:59 PM
sgcuda Offline OP
sgcuda  Offline OP
So carbon fiber is out, but what advantages are there going to aluminum over steel, if any? Even the weight difference should account for something. Hey Poly, you seem to be in agreement with outlawssaa that there is no advantage. In the automotive world, I see you as Steven Hawking's cooler brother. My driveshaft is very close to stock length, so there should be a considerable amount of weight loss using aluminum over steel. Why would this not be a benefit ie: why won't the car be any quicker?
[image][/image]
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898607
08/24/15 09:15 PM
08/24/15 09:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Alum is a 2 to 1 ratio(basic figure) so you double the
wall thickness and loose 1/4 of the weight... yes weight
is a major factor in racing and I always push the light
weight... but the price and how close it is to center line
doesnt make much if any ET but does take weight out of the
wallet
EDIT
Every DS I have had made has been DOM... and thats not cheap
wave
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898611
08/24/15 09:21 PM
08/24/15 09:21 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Weight is weight............If I can buy a part that is just as good or better, plus it weighs less.........that's what I use. Ounces make pounds and 1 pound savings here and there, eventually make 10 pound savings and so on. Nice Carbon shafts can be bought in the $800 range from certain places and a good alum shaft from Denny's etc will set you back $500. So it depends on whether the extra $300 is worth it to you from a little weight and additional safety aspect
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898623
08/24/15 09:29 PM
08/24/15 09:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I had a drive shaft built for my 71 BB street car by a local drive line place that does everything including big trucks.
It was back in 2005 but I remember that the aluminum shaft was not much more than steel one and I went with aluminum. Been great for 10 years now. Got a healthy 440 6pak with a dana. Got rid of a 8 3/4 and that's why I needed a new drive shaft.
Go aluminum IMO, it's lighter and lighter is always good.
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: Monte_Smith] #1898632
08/24/15 09:37 PM
08/24/15 09:37 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
This is the reason I have a carbon fiber drive shaft. My tunnel is aluminum with 2 safety loops. I would not want one banging around in there that close to my seat. Well that and the fact my buddy had one that would no longer fit his car but worked for mine and I got a smoking deal.
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898633
08/24/15 09:37 PM
08/24/15 09:37 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Because it is rotational weight, IF there is a measurable difference, I would think it would be in the 60' time and it would be in the range of .0000X.
The biggest draw on power is accelerating the shaft from 0 RPM. Once it has been accelerated past zero it's a law of diminishing returns thing with the initial return being 2/3rds of 5/8ths of not much.
Where the aluminum and CF shafts will pay is when you are approaching/running 10K RPM shaft speeds.
Kevin
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: Monte_Smith] #1898638
08/24/15 09:42 PM
08/24/15 09:42 PM
Cincinnati, Ohio
Cincinnati, Ohio
I had a 290" TAD dragster rebodied at Murff McKinneys place with Magnesium panels one time.
They took a bucket and saved all the small pieces he cut off my car mounting the new body and it weighed a lot. Then he showed me many places on my car where we could save weight and those were incorporated into the next car. Grams add up to ounces and ounces add up to pounds. Been there. I had 49# hanging on the nose of my current car just to make minimum weight which is great.
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898648
08/24/15 09:55 PM
08/24/15 09:55 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
EXACTLY............you can't say, well this only weighs five pounds, that won't hurt anything. Do that 10 times and you stack 50lbs on your car for no reason.
I look at weight one way..........and that is, does the car absolutely positively NEED this part. And if it does NEED this part, how do I make said part lighter
Re: Driveshafts: Steel vs. Aluminum vs. Carbon Fiber [Re: sgcuda] #1898687
08/24/15 10:56 PM
08/24/15 10:56 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Carbon driveshaft.......
A measure of safety AND weight reduction, for a relatively small investment.
win/win
