Re: Help Please 2005 / 2006 HEMI engines
[Re: newport100]
#1898590
08/24/15 08:51 PM
08/24/15 08:51 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
You need to swap out the lifters for the non-mds flavor, perhaps rob a few out of your old engine. Swapping lifters requires removing heads. Other than that you gots your pan/pickup, intake manifold (I think is different) and ex manifolds. There is a ring in the crank you need to remove to fit on the snout of the truck TQ converter.
If it really blew bad make sure no shrapnel ended up in the intake.
That should just about do it.
[Re: newport100]
#1908961
09/08/15 11:55 PM
09/08/15 11:55 PM
HotRodDave
Kalispell Mt.
3 out or 4 bad ones I see are just snapped rods with no other issues, second most is when someone overheats it the valve seat and or guides fall out wreaking all kinds of havock on the pistons, head castings, bores...
[Re: newport100]
#1909272
09/09/15 03:01 PM
09/09/15 03:01 PM
HotRodDave
Kalispell Mt.
I have no solid proof but I think maybe the powdered metal rods were just not thick enough and the surface texture when they are done leaves millions of tiny stress risers so they get a little crack and just snap. If it was hydro locking they would be bent or something. Except where the big end hit the block it looks like you could just put the two pices back together and keep running.
[Re: newport100]
#1909309
09/09/15 04:00 PM
09/09/15 04:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Powered metal rods have been around, from a lot of manufacturers, for a long time. Nothing inherently wrong with them, but that's not to say the implementation is proper either. I hydrolocked the engine in my wife's Neon once, the powered metal rods in that 4 cylinder indeed bent.
[Re: newport100]
#1909317
09/09/15 04:05 PM
09/09/15 04:05 PM
Posts: 15,902 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'm thinking by the o/p words, he overheated his. And who knows, might be very high miles based on the year of the vehicle.
Facts are stubborn things.
