Ram 1500 - Correct tire inflation psi?
#1898316
08/24/15 02:02 PM
08/24/15 02:02 PM
Posts: 1,106 Northeast
VincentVega
Northeast
I have a 2005 Ram 1500, 4x4, standard cab short bed. I have LT245/17" sized tires on it, General Grabber TR. Load Range D. Says max PSI 65 cold I cannot find what the recommended inflation pressure is for this. I'm going to be moving across the country with it, carrying two people and several hundred pounds of cargo. The door sticker says 35psi.. but that was for the factory style tires (20" aluminum rims). I think those were basically car tires, but I may be mistaken Any recommendations? Thanks!
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Ram 1500 - Correct tire inflation psi?
[Re: VincentVega]
#1898429
08/24/15 04:25 PM
08/24/15 04:25 PM
Posts: 13,601 md
mopars4ever
md
my door sticker on my 06 ram 2500 with lt265/17E is 60 front with 45 back on light loads and 60 front 70 back on max load
[Re: VincentVega]
#1898498
08/24/15 05:57 PM
08/24/15 05:57 PM
Challenger 1
Cincinnati, Ohio
I have a 2005 Ram 1500, 4x4, standard cab short bed. I have LT245/17" sized tires on it, General Grabber TR. Load Range D. Says max PSI 65 cold I cannot find what the recommended inflation pressure is for this. I'm going to be moving across the country with it, carrying two people and several hundred pounds of cargo. The door sticker says 35psi.. but that was for the factory style tires (20" aluminum rims). I think those were basically car tires, but I may be mistaken Any recommendations? Thanks! I am thinking that the tire on the truck now is larger than original so like you said the tires and rims were different. Don't try to run 35 psi in those tires, ever and you know that. I highly recommend that you run them at 65psi during your move and on long highway trips. Then when you get where your going with less load you could easily take 15psi out to help the truck ride better around town. But not under load and on long highway trips.
[Re: VincentVega]
#1899221
08/25/15 05:48 PM
08/25/15 05:48 PM
Posts: 13,601 md
mopars4ever
md
[Re: VincentVega]
#1899515
08/26/15 12:59 AM
08/26/15 12:59 AM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
Holy bad advice in this thread. All of it.
Mo' Farts
Moderated by "tbagger".
[Re: VincentVega]
#1899898
08/26/15 06:54 PM
08/26/15 06:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My wife had an 05 Ram 1500 SLT, 2wd, with those sized tires. Inflation pressure was 35psi on the door jamb, I think someone missed seeing that size on the Firestone site, it's there.
Owner's manual should have it too, for all factory installed sizes. To save you the search they are all 35 psi.
[Re: VincentVega]
#1899916
08/26/15 07:30 PM
08/26/15 07:30 PM
Posts: 13,601 md
mopars4ever
md
All of it. twocents
Give some good advice. What you got?
[Re: VincentVega]
#1900031
08/26/15 10:43 PM
08/26/15 10:43 PM
Posts: 6,008 Salem
Grizzly
Salem
Probably a waste of time, but: Whatever is on the door sticker goes out the window when you take the factory tires off, and you sure as hell don't run the "max" pressure unless you are loaded to the max. Are you carrying 7200 pounds on this trip? Mine are stamped 3200 each x 4 minus the weight of the truck, and that's what I would have to be hauling to go to 65 pounds. Go by the bulge of the tire and the wear pattern, every tire is different. My Michelins are "D" rated on my 5600 lb QuadCab I settled on 46 front, 44 rear. Lots of long distance trips with 800 pounds in the back at those pressures as well. Only time I ever put 60 in the back is when I'm towing a 7000 pound trailer. For those who are certain to argue with me, here: 161,000 miles on these tires, see any problems?
Mo' Farts
[Re: VincentVega]
#1900169
08/27/15 01:43 AM
08/27/15 01:43 AM
Supercuda
About to go away
About to go away
up yours
Seems no one understands that the size he has on his truck right now is a factory installed size. Factory recommended pressures apply.
[Re: VincentVega]
#1900411
08/27/15 02:28 PM
08/27/15 02:28 PM
Supercuda
About to go away
About to go away
up yours
The listing on the tire refers solely to the tire's maximum capacity, which can very well exceed the truck's maximum capacity
The listing on the truck is a determination by the vehicle manufacturer of the proper pressure to safely carry the rated load of the truck while allowing for proper wear of the tire.
Too little pressure wears the outsides of the tread, too much wears the center of the tread. Both decrease traction.
More air increases the tires ability to carry a load, less air decreases it. However, pumping up the pressure doesn't allow the truck to carry more load.
[Re: VincentVega]
#1903276
08/31/15 05:27 PM
08/31/15 05:27 PM
VincentVega
Northeast
I appreciate the activity here. The back and forth is exactly what was going on in my mind. Symmetry
Anyway, as mentioned, 35psi is on the door. I didn't find it in the manual, but it's probably there somewhere.
The factory tires were passenger car tires.. the P275 20s. I ran them at car-ish pressures (30-32) and the centers still wore out first. So, I probably should have kept them around 28 as that usage was commuting and not hauling.
Using that as a baseline, I'd expect the LT tires would behave no differently. It's not like they react differently to air pressure. I have them at 35psi right now. As a rough guess, I'd say about a 1000 lbs of cargo including passengers. maybe between 6000 and 6200 total weight. It's only 1200 miles to my destination. (I'm sure it will feel like a million at the end)
At that PSI the sidewall looks fine. definitely does not look underinflated. I suppose a higher PSI would help keep us awake over the supposed 20 hour trip, but I'd rather try to not adversely wear out the centers. I suppose if I believe anything bad is going on, I can just air up at a gas station
Thanks for the effort.
[Re: VincentVega]
#1904795
09/02/15 12:12 PM
09/02/15 12:12 PM
Posts: 6,008 Salem
Grizzly
Salem
You betcha, probably one of the best looking wheels ever for the 2nd Gens. They even look pretty cool on a 2wd.
How's that Off-Road of yours been holding up? Just over 235,000 on mine and my replacement trans seems to be holding up.
Mo' Farts
