Re: Damper Question
[Re: justinp61]
#1898785
08/25/15 12:53 AM
08/25/15 12:53 AM
Posts: 43,287 Bend,OR USA
Cab_Burge
Thanks Rebel, the crank snout looks fine. Just want to make sure I get the right damper for my build.
I figured with all the replies the "balancer" post some guys might weigh in here. Lot's of opinions, I run XXX and don't run YYY but no substance. When in doubt, change it out I like and use ATI now
Re: Damper Question
[Re: MR_P_BODY]
#1898886
08/25/15 08:08 AM
08/25/15 08:08 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I dont know for fact but I had heard Romac was sorta on the junk side of balancers....but I have never used one But what makes them junk? When I bought it they were supposed to be decent balancers. I don't think ATI makes a hub set up that will work with stock pulleys. I tried to call them but the tech guy was busy. Thanks
Re: Damper Question
[Re: justinp61]
#1899857
08/26/15 05:16 PM
08/26/15 05:16 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
My ATI damper has the stock pulley spacing if I'm not mistaken. Ran the same drive setup I always used to for a while before I switched to electric water pump and all.
Re: Damper Question
[Re: justinp61]
#1901058
08/28/15 01:10 PM
08/28/15 01:10 PM
an8sec70cuda
I have a Fluidamper on the 440 that was in my cuda before I put the hemi in it. The hemi has an ATI on it. I used the same pulley setup on both motors for a while. I had a moroso underdrive crank pulley and a factory water pump pulley on it.
