Are big & small blocks the same flywheel? #1897956
08/23/15 10:27 PM
08/23/15 10:27 PM
North East Missouri
E
express Offline OP
express  Offline OP
E
North East Missouri
Friend called me & his 440 with steel crank is ready for the dyno. It will be an auto car but shop need a flywheel to hook it to the dyno. Shop says any small block or big block flywheel will work for this.
Now I know that 360's & cast crank flywheels won't work but will a 340 work on a 440?
Thanks!
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: Are big & small blocks the same flywheel? [Re: express] #1897962
08/23/15 10:33 PM
08/23/15 10:33 PM
There are several OEM 6 bolt A motor internally balanced motors, 273,318,340, 130 tooth nuetral balance flywheels that will work on either the BB, 426 Hemi and B and RB internally balanced motors, same on the internally balanced motors with the larger 143 tooth flywheels up The key is internally balanced motors using a nuetral balanced flywheel, aluminum, stee, 130 or 143 tooth thumbs IHTHs
Re: Are big & small blocks the same flywheel? [Re: express] #1897979
08/23/15 10:49 PM
08/23/15 10:49 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I don't know if this will help you or not but my internally balanced 408 small block uses the same powerglide flex plate as my big blocks. Lots of used outdated sfi flex plates are bought for this purpose
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Are big & small blocks the same flywheel? [Re: express] #1897982
08/23/15 10:49 PM
08/23/15 10:49 PM
North East Missouri
E
express Offline OP
express  Offline OP
E
North East Missouri
Soooooo, It will work?
Re: Are big & small blocks the same flywheel? [Re: Cab_Burge] #1898013
08/23/15 11:27 PM
08/23/15 11:27 PM
North East Missouri
E
express Offline OP
express  Offline OP
E
North East Missouri
Originally Posted By Cab_Burge
There are several OEM 6 bolt 130 tooth nuetral balance flywheels that will work on either the BB, 426 Hemi and B and RB internally balanced motors, same on the internally balanced motors with the larger 143 tooth flywheels up The key is internally balanced motors using a nuetral balanced flywheel, aluminum, stee, 130 or 143 tooth thumbs IHTHs
So if he gets any 6 bolt flywheel that is for an internally balanced motor it will work?
Re: Are big & small blocks the same flywheel? [Re: express] #1898015
08/23/15 11:28 PM
08/23/15 11:28 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
In a word, YES! Any 6-bolt internally balanced flywheel will work. wave
JB Rhinehart, Realist
A-Body's RULE!
Re: Are big & small blocks the same flywheel? [Re: express] #1898159
08/24/15 03:52 AM
08/24/15 03:52 AM
upI messed up and forgot to include A motor flywheels on my original post, sorry blush See the post now with the edit, Rhinodart is correct bow
Re: Are big & small blocks the same flywheel? [Re: express] #1898319
08/24/15 02:05 PM
08/24/15 02:05 PM
dogdays Offline
dogdays  Offline
That's what that spare 318 sitting in the corner is for.
R.
Re: Are big & small blocks the same flywheel? [Re: Rhinodart] #1898325
08/24/15 02:20 PM
08/24/15 02:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
YEs ASSuMEing the 440 in question is also internal balance ... which the OP never says ...
Re: Are big & small blocks the same flywheel? [Re: JohnRR] #1898530
08/24/15 07:02 PM
08/24/15 07:02 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
10.5" - 130 tooth - YES
11" - 143 tooth - YES (they did come on some LA truck motors)
11" - 172 tooth (Hemi 66-67) - NO
What # of teeth does this dyno already use is the BIG question. If 130T, then get a 10.5" and you're good to go.
Re: Are big & small blocks the same flywheel? [Re: express] #1899392
08/25/15 10:28 PM
08/25/15 10:28 PM
North East Missouri
E
express Offline OP
express  Offline OP
E
North East Missouri
OK thanks for all of the help! Now I know what to tell him.
