Have I killed my Turbo Start Restoration Battery?
#1897385
08/22/15 11:29 PM
08/22/15 11:29 PM
Posts: 1,131 Kent, WA
triple_green
Kent, WA
I have one of the AGM (Absorbed Glass Mat) group 27 Restoration Batteries. I'm Pretty sure this battery is 15 years old. I could not find he receipt, but I know it was done during that last part of the restoration. (drive 2500 miles a year mostly in summer)
It as never failed me and starts and cranks strong every time up to this point.
when I was reinstalling the radiator I must have bumped the negative battery cable and it was brittle apparently it was almost broken off, but I couldn't see the break. I tried to crank the car over multiple times and finally it drained all the juice. When I went to inspect the cable connections again it just broke off in my hands.
I put new + and - cables. Jumped the battery drove around a little. 15 min later it wouldn't start.
jumped it and took it over to my mechanic. He said it was the voltage regulator. Got a new one, jumped the battery and drove it home. 15 min later it is dead again. Mechanic said the battery appears to not be holding a charger. But...
Charged it for an hour yesterday with a battery charger. Started up and drive great yesterday. 3 times both hot and cold. Took it on several short trips today and a 10 mile drive.
It started several times both hot and cold. Seemed to charge up right a way (dash amp meter) and not discharging to any degree.
A new one of these Turbo start batteries is $320 from Remy. Am I just fooling myself to think it will last a little longer? Am I just running of the charge from the battery charger and it will crap out in a couple of days?
Thanks! (sorry this is long)
68 Charger, 383 HP console auto, spring green, stock restoration
Re: Have I killed my Turbo Start Restoration Battery?
[Re: triple_green]
#1897437
08/23/15 12:36 AM
08/23/15 12:36 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Wait a few days and see what happens.
Chris from New Jersey
[Re: 62maxwgn]
#1897630
08/23/15 12:55 PM
08/23/15 12:55 PM
triple_green
Kent, WA
Thanks all for the answers.
[Re: triple_green]
#1897654
08/23/15 01:24 PM
08/23/15 01:24 PM
RapidRobert
You might check the cranking voltage at the battery next time but it sure sounds like the battery is done. sometimes even if a good battery is discharged all the way it will kill it. Agreed, 15 yr life is unheard of! what I'd do is toss in another battery from one of your other Mopars & that would confirm that all is good in the 'hood ex the battery
[Re: triple_green]
#1897801
08/23/15 06:13 PM
08/23/15 06:13 PM
triple_green
Kent, WA
Mancini shows out of stock, but I will call them.
62maxwagon, is that a lead acid battery or sealed? Thanks!
[Re: triple_green]
#1897916
08/23/15 09:39 PM
08/23/15 09:39 PM
Posts: 6,224 JERSEY
RJS
JERSEY
62maxwagon, is that a lead acid battery or sealed? Thanks! The "early" script shows out of stock but I ordered this one "late" script. Don't know what the difference is and didn't care. I was wrong about price it's $250. Just got my car running this week and battery is perfect. Ron http://www.manciniracing.com/mos2lareba.html
[Re: triple_green]
#1898009
08/23/15 11:18 PM
08/23/15 11:18 PM
triple_green
Kent, WA
So no diff other than the script?
Mine is a late model year built. might have even had a 69 battery.
thx
