Re: 1998 Ram new starter and still just clicking!
[Re: hellrzr]
#1897827
08/23/15 06:46 PM
08/23/15 06:46 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Hook a test light to negative battery terminal. Stab into the positive lead that feeds the starter. Light should be on. Try starting it. If the light goes out, the connection at your terminal end is bad. If it stays lit, mount the test light on the engine block to negative battery. If it lights up when cranking, you lost your ground from engine to battery.
[image][/image]
