1980 D100 STEP SIDE FUEL TANK #1897496
08/23/15 01:44 AM
08/23/15 01:44 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
PLASTIC TANK HAS A COUPLE CRACKS IN IT. ANYONE KNOW OF A FIX OR WHERE TO GET A NEW ONE.
Re: 1980 D100 STEP SIDE FUEL TANK [Re: rickb67] #1897506
08/23/15 02:17 AM
08/23/15 02:17 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
You'll not likely find a new one, so a donor or proper repair will be your options. But repairing poly plastics are difficult because nothing sticks - at least for any length of time.
I have used this on door panels, plastic dirt bike fenders, urethanes, etc. It is simply amazing and works as advertised: http://www.urethanesupply.com/Airless-Welders-1/Micro-Weld-80/
Re: 1980 D100 STEP SIDE FUEL TANK [Re: rickb67] #1897855
08/23/15 07:43 PM
08/23/15 07:43 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I weld them using a soldering iron
Re: 1980 D100 STEP SIDE FUEL TANK [Re: BulletBob] #1898401
08/24/15 03:50 PM
08/24/15 03:50 PM
dogdays Offline
dogdays  Offline
Do a google search for plastic fuel tank repair. A body shop in your neighborhood may be able to weld it for you.
R.
Re: 1980 D100 STEP SIDE FUEL TANK [Re: dogdays] #1898651
08/24/15 10:02 PM
08/24/15 10:02 PM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
thank you i have a direction now.
Re: 1980 D100 STEP SIDE FUEL TANK [Re: rickb67] #1899605
08/26/15 06:33 AM
08/26/15 06:33 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I use the same plastic as the tank is made from to weld with
