Radiator Puzzler??? #1896705
08/21/15 06:56 PM
08/21/15 06:56 PM
Fargo ND
moparphilll Offline OP
Fargo ND
Haven't popped the hood since last fall and found radiator collapsed on top? Possible problem?
Re: Radiator Puzzler??? [Re: moparphilll] #1896710
08/21/15 07:05 PM
08/21/15 07:05 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Superbird defect, please send the car to me I will take care of the problem. drive
Re: Radiator Puzzler??? [Re: moparpollack] #1896725
08/21/15 07:27 PM
08/21/15 07:27 PM
USA
Hooligan Offline
Hooligan  Offline
USA
HILARIOUS!!! Umm, referring to the wise crack, not the radiator mystery.
Re: Radiator Puzzler??? [Re: moparphilll] #1896757
08/21/15 08:22 PM
08/21/15 08:22 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I have seen top tanks like that before, but just assumed that it was from some morn like me putting his knees there while working on something toward the rear of the engine.
Hard to believe vacuum from a stuck cap would do that ...
It takes gasoline to interest me.
Re: Radiator Puzzler??? [Re: VL21] #1896816
08/21/15 09:25 PM
08/21/15 09:25 PM
Fargo ND
Fargo ND
Replace the cap you say?
Re: Radiator Puzzler??? [Re: moparphilll] #1896856
08/21/15 10:29 PM
08/21/15 10:29 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Most likely due to vacuum sucking it down maybe when the eng.heats up & builds pressure it will reverse its self.On a side note what's that 71 a RR or GTX.
Re: Radiator Puzzler??? [Re: moparphilll] #1896862
08/21/15 10:44 PM
08/21/15 10:44 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
does your rad cap have a "hanging" vent valve disc or is it spring loaded? ronnie
Re: Radiator Puzzler??? [Re: 1969ronnie] #1896914
08/22/15 12:01 AM
08/22/15 12:01 AM
Fargo ND
Fargo ND
spring
Re: Radiator Puzzler??? [Re: moparphilll] #1896917
08/22/15 12:02 AM
08/22/15 12:02 AM
Fargo ND
Fargo ND
RoadRunner!
Re: Radiator Puzzler??? [Re: moparphilll] #1896954
08/22/15 02:02 AM
08/22/15 02:02 AM
I ain't sayin vac pulled it down but if it did (if it was that weak/fatigued) you'd think psi would pop it back up when running ???
Re: Radiator Puzzler??? [Re: moparphilll] #1897189
08/22/15 05:16 PM
08/22/15 05:16 PM
1969ronnie Offline
1969ronnie  Offline
phill,not the big pressure spring you see.turn rad cap over from your last picture.take your finger nail and pull the silver disc "mopar hanging vent valve " down.it should NOT spring back up but hang free from rubber . get a real mopar rad cap so you don't ruin another 956 rad. bob s @ glenray rad.com will fix you up. ronnie
Re: Radiator Puzzler??? [Re: 1969ronnie] #1897269
08/22/15 08:00 PM
08/22/15 08:00 PM
Ding ding ding I do believe we have a winna
Re: Radiator Puzzler??? [Re: RapidRobert] #1897384
08/22/15 11:27 PM
08/22/15 11:27 PM
Fargo ND
Fargo ND
well bummer I remember putting a new cap on it a few years ago cuz it always spit on the ground after shutdown. guess I will put the old one back on
Re: Radiator Puzzler??? [Re: moparphilll] #1897387
08/22/15 11:29 PM
08/22/15 11:29 PM
Fargo ND
Fargo ND
Glen ray No way I have a stash of 956's
Re: Radiator Puzzler??? [Re: moparphilll] #1897487
08/23/15 01:30 AM
08/23/15 01:30 AM
If the old one let it puke then either the psi was sky high or the main thick spring in the cap was weak. I would instead get a new one & just confirm the thin metal disc at the bottom is loose/free (& since it is new/likely the disc is good there)
Re: Radiator Puzzler??? [Re: RapidRobert] #1897536
08/23/15 08:01 AM
08/23/15 08:01 AM
Fargo ND
Fargo ND
Thanks thumbs
