alternator magnet test
#1897146
08/22/15 03:43 PM
08/22/15 03:43 PM
Posts: 614 ont,canada
mopartuner
ont,canada
If a wrench doesn't get pulled into the back of the alternator it means its no good......why?is there any other reason this isn't magnetized?
410 pump gas solis flat tappet cam 10.95 so far
Re: alternator magnet test
[Re: mopartuner]
#1897165
08/22/15 04:27 PM
08/22/15 04:27 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Don't think that's correct. Alternator generates alternating current then rectifies through diodes.
[Re: 67_Satellite]
#1897259
08/22/15 07:28 PM
08/22/15 07:28 PM
Posts: 403 southern Maryland
keefe
southern Maryland
If I remember correctly.. if the alternator is good it will cause a magnetic field regardless of the voltage regulators condition. That's how we use to trouble shoot a bad alt. or reg.
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
[Re: keefe]
#1897556
08/23/15 10:21 AM
08/23/15 10:21 AM
Leon441
Lynchburg, VA
Always used a meter.
Didn't realize the stator shaft poles when charging.
[Re: mopartuner]
#1897644
08/23/15 01:15 PM
08/23/15 01:15 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
If a wrench doesn't get pulled into the back of the alternator it means its no good......why?is there any other reason this isn't magnetized? If it pulls, it means everything is working. If it doesn't, there is a problem, but it doesn't tell you where. Could be alternator, regulator, field wiring or B+. Just a quick Good/No good check.
[image][/image]
[Re: sgcuda]
#1897657
08/23/15 01:26 PM
08/23/15 01:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If a wrench doesn't get pulled into the back of the alternator it means its no good......why?is there any other reason this isn't magnetized? If it pulls, it means everything is working. If it doesn't, there is a problem, but it doesn't tell you where. Could be alternator, regulator, field wiring or B+. Just a quick Good/No good check. I never heard of the test of if its magnetic its good.. you have to energize the field to create the field... I always use to try a full field test first at the regulator.. if it works then change the reg.... a vom can test a lot of things
[Re: mopartuner]
#1897662
08/23/15 01:30 PM
08/23/15 01:30 PM
sgcuda
Try putting a screwdriver blade to the back of any alternator. It will always pull down on a working charging system. This is old school I learned from my first boss when I was in the gas stations and regular gas was still available (am I showing my age a little?).
[image][/image]
[Re: mopartuner]
#1897700
08/23/15 02:33 PM
08/23/15 02:33 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Keep in mind... That an alternator may still have some output but be below spec...Put a voltmeter on it, should have 13.5-14.5V output. If U dont have a voltmeter, check with Harbor Freight they have a give-away one or sells for $5.. Just my $0.02...
