Condensation In Oil?
#189657
01/10/09 05:10 PM
01/10/09 05:10 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
I changed the oil in my 04 Ram Hemi today noticed a LOT of condensation under the fill cap (it has the big plastic one that the new cars have)-enough that 5-6 drops of water went back down the fill tube. Before I filled the crankcase again, I let it ventilate for about an hour. After I refilled the crankcase, I ran it for a few minutes (not to operating temp but enough to warm it up a little) and didnt see any water in the oil, or hear anything bad and psi was normal. I checked the PCV valve it was OK.
Then I looked at my wife's Durango (4.7) which has the same fill cap as the Hemi. It was also wet with yellow jelly coagulated on the bottom. Again, the oil looked fine and its not due for an oil change for another 1000 miles.
Maybe I just never noticed it before but is this normal for all this condensation to sit up under fill caps on these engines? They seat very tight and I can see how the crankcases dont breathe as well as the older engines screw-in fill caps and breathers in the valve cover (the PCVs on both trucks tested OK)
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
Re: Condensation In Oil?
[Re: 05dakota]
#189659
01/10/09 05:45 PM
01/10/09 05:45 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Perfectly normal. In cooler weather it builds faster than in warm. Only cure is to drive the vehicle till it is thoroughly warmed up (not just the gauge reading) which only tells the coolant temp but not the system temp. everything has to have a chance to get to operating temperature and for long enough for condesants to be evaporated out of the system. Condensation is a natural thing for any internal combustion engine and really not just in cold temperatures. They are just more prevalent and harder to get rid of the colder it is. Another reason for frequent oil changes in colder temperatures.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: RangerDan440]
#189660
01/10/09 06:20 PM
01/10/09 06:20 PM
RangerDan440
its been exceptionally cold lately so I guess thats why I thought it seemed it excessive. I hate winter
[Re: RangerDan440]
#189663
01/10/09 09:28 PM
01/10/09 09:28 PM
Posts: 13,049 The Thumb O' Michigan
Fluffy
Automotive STD Guy
Automotive STD Guy
I hate winter
Weenie.
On the 4.7 they make a rerouted PCV for the 4.7 to fix that problem. However, if you just switch to Synthetic fluids, it'll fix itself in a couple of oil changes.
[Re: Fluffy]
#189665
01/10/09 10:03 PM
01/10/09 10:03 PM
MoparforLife
Upper Midwest
I hate winter
Weenie.
Synthetic oil does not cure condensation. Condensation will occur no matter what oil you have and it will contaminate it just as much. Don't kid you self.
