'65 Belvedere #1895507
08/19/15 06:34 PM
08/19/15 06:34 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
what do they weigh with a sm blk?
seems in '65 they weren't overly large
Re: '65 Belvedere [Re: can.al] #1895509
08/19/15 06:37 PM
08/19/15 06:37 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Mine was 3800 with a 440/727 before the turbos went in.
- Stu Harmon
Re: '65 Belvedere [Re: feets] #1895583
08/19/15 08:20 PM
08/19/15 08:20 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
3800
big block,727....
more details...
Re: '65 Belvedere [Re: can.al] #1895959
08/20/15 03:13 PM
08/20/15 03:13 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
3941 on mine. Iron 440, ac, 727, 1/2 tank fuel, me not in it.
Carl Kessel
Re: '65 Belvedere [Re: can.al] #1896033
08/20/15 05:28 PM
08/20/15 05:28 PM
Is that a Belvedere 1 or 2? Two door sedan or hardtop?The SB 273 motors are around two hundred pounds lighter than the B or RB motors, the poly 318 are probally between those two confused IHTHs
Re: '65 Belvedere [Re: can.al] #1896255
08/20/15 10:48 PM
08/20/15 10:48 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Ooopps. My car is a Coronet 500. Most likely not much difference between the family members.
Carl Kessel
