Re: '65 Belvedere
[Re: can.al]
#1895509
08/19/15 06:37 PM
08/19/15 06:37 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Mine was 3800 with a 440/727 before the turbos went in.
Re: '65 Belvedere
[Re: can.al]
#1895959
08/20/15 03:13 PM
08/20/15 03:13 PM
Posts: 670 Los Osos, Ca
CKessel
Los Osos, Ca
3941 on mine. Iron 440, ac, 727, 1/2 tank fuel, me not in it.
Carl Kessel
Re: '65 Belvedere
[Re: can.al]
#1896033
08/20/15 05:28 PM
08/20/15 05:28 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Is that a Belvedere 1 or 2? Two door sedan or hardtop?The SB 273 motors are around two hundred pounds lighter than the B or RB motors, the poly 318 are probally between those two IHTHs
Re: '65 Belvedere
[Re: can.al]
#1896255
08/20/15 10:48 PM
08/20/15 10:48 PM
CKessel
Los Osos, Ca
Ooopps. My car is a Coronet 500. Most likely not much difference between the family members.
Carl Kessel
