360 SB RUNNING ROUGH NEW BUILD #1894873
08/18/15 10:36 PM
08/18/15 10:36 PM
SO ILL
K
KISSFANN1 Offline OP
K
SO ILL
This is a fresh built engine. All new parts.
Less than 1 hour of run time.
Broke cam in for over 20 minutes in Jan.
Ran great in short time start ups.
Then all the sudden it started running rough.
While it can run, I pulled spark plug wire # 3,5,2, & 8.
The running rough does not change.
When the others are pulled, the running changes.
What is the correlation between #3,5,2, & 8 timing?
I welcome any suggestions to help me thru this crisis.
Thanks,
SLD
Re: 360 SB RUNNING ROUGH NEW BUILD [Re: KISSFANN1] #1894902
08/18/15 10:53 PM
08/18/15 10:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
intake manifold if it's a dual plane, one side feeds those cylinders. Probably a carb issue.
Don't be the exception.
Re: 360 SB RUNNING ROUGH NEW BUILD [Re: KISSFANN1] #1894914
08/18/15 11:03 PM
08/18/15 11:03 PM
SO ILL
K
K
SO ILL
It is a original 70's model 4 barrel intake.
Does that it make it a dual plane?
How do I determine that?
Thanks,
SLD
Re: 360 SB RUNNING ROUGH NEW BUILD [Re: KISSFANN1] #1894935
08/18/15 11:14 PM
08/18/15 11:14 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It should be a dual plane. Last mopar 4 bbl intake I saw that was factory single plane was a 273 commando of 67 vintage.
Re: 360 SB RUNNING ROUGH NEW BUILD [Re: KISSFANN1] #1898734
08/24/15 11:52 PM
08/24/15 11:52 PM
SO ILL
K
K
SO ILL
Supercuda,
You were spot on.
The float was stuck on the left side of the carb.
Quick cleaning and back to running great.
Thanks,
SLD
Re: 360 SB RUNNING ROUGH NEW BUILD [Re: KISSFANN1] #1898752
08/25/15 12:11 AM
08/25/15 12:11 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Glad you found it
