440 truck exhaust with manifolds #1894280
08/18/15 12:07 PM
08/18/15 12:07 PM
Eastern Ontario
shaker340 Offline OP
Eastern Ontario
Does anyone know where to get down pipes for use with exhaust manifolds for big block in 61-71 d100 trucks?
Thanks, Mike
2008 Challenger SRT8
1940 Chrysler Royal coupe
Re: 440 truck exhaust with manifolds [Re: shaker340] #1896309
08/21/15 12:29 AM
08/21/15 12:29 AM
IL
BlwnCrcab Offline
BlwnCrcab  Offline
IL
any custom exh.shop can do it
Re: 440 truck exhaust with manifolds [Re: BlwnCrcab] #1896619
08/21/15 04:23 PM
08/21/15 04:23 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Unless he's looking for mandrel bent...?
Re: 440 truck exhaust with manifolds [Re: DaytonaTurbo] #1896961
08/22/15 02:29 AM
08/22/15 02:29 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Trucks used a flat flange welded to the down pipe with a gasket.....
Ed
Re: 440 truck exhaust with manifolds [Re: Mr. Smurf] #1903773
09/01/15 10:09 AM
09/01/15 10:09 AM
Eastern Ontario
Eastern Ontario
Actually I was hoping for over the shelf pre bent down pipes to get it past the transmission. Don't have anything at the moment and no trailer to tow to exhaust shop.
Re: 440 truck exhaust with manifolds [Re: shaker340] #1904695
09/02/15 05:11 AM
09/02/15 05:11 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Do you have a welder
Re: 440 truck exhaust with manifolds [Re: shaker340] #1904887
09/02/15 01:48 PM
09/02/15 01:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried the walker exhaust site? You might be able to find what you need and get a part number to check at the local part stores. Or like was said earlier any good muffler shop can make what you need.
Re: 440 truck exhaust with manifolds [Re: stumpy] #1905580
09/03/15 11:34 AM
09/03/15 11:34 AM
Eastern Ontario
Eastern Ontario
Stumpy, I will try the walker site. Yes I do have a Mig welder.
