Re: Dropped a tiny lock washer into open engine
[Re: Black_Bee]
#1894277
08/18/15 12:03 PM
08/18/15 12:03 PM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
Jack the car up so it angles the engine back. Put a 12" or larger sub-woofer under your oil pan. Play some appropriate rap, preferably gangsta rap with explicit lyrics, at a very high volume. The vibes should make the washer wanna chill in the oil pan, and probably smoke blunts. From there, you can fish it to the drain hole with a magnet. Sometimes you gotta think outside the (speaker) box. ![apimp apimp](/ubbthreads/images/graemlins/custom/apimp.gif)
[Re: 65Fury440]
#1894365
08/18/15 01:57 PM
08/18/15 01:57 PM
dogdays
Bah!
Can't believe we're still on this non-issue. Does he or does he not have a screen on the intake of his oil pump? If there is a screen, end of story. A magnetic drain plug would be nice, or a magnet epoxied to the outside of the bottom of the pan would work.
We need to get out of this oh-so-scary car business and take up crocheting. Knitting is too dangerous, those sharp needles!
R.
[Re: dogdays]
#1894484
08/18/15 03:46 PM
08/18/15 03:46 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The pan is steel. No need for epoxy. It will be happy to hold itself in place.
[Re: Black_Bee]
#1894605
08/18/15 06:08 PM
08/18/15 06:08 PM
Posts: 6,717 KY
65pacecar
KY
