Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1893301
08/16/15 11:57 PM
08/16/15 11:57 PM
Uranus
strokerchall Offline OP
Uranus
The 165 was in it,it never runs at 165 so not big deal.The minimum heat it has ever run was 180. I'm going to get a overflow can.
Also I believe the reason the car runs close to 200 on the highway is the 4:10 gears,runs at 3300 rpm at 60mph
once you've stroked it,you'll wish you stroked it sooner
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: BigBlockMopar] #1893305
08/17/15 12:01 AM
08/17/15 12:01 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By BigBlockMopar
Originally Posted By Sinitro
A friend ran 1 of these on his stroker 440, it ran hot...
Swapped it out for the Mopar performance part, tempeature dropped 10 degrees in So Cal traffic..
Did the guy ever check the pump vane clearance against both housings?
Did he also change waterpumps?
Exactly.
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1893310
08/17/15 12:03 AM
08/17/15 12:03 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Why is it puking coolant at 200°? Is your gauge wrong?
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: BSB67] #1893316
08/17/15 12:07 AM
08/17/15 12:07 AM
Uranus
Uranus
the fluid obviously expands,202 is the boiling point of water.The fluid level is down about 3/4" every week or so,depending on outside temp.I've only ever seen it drip a little.
Re: 440SOURCE WATER PUMP HOUSING....JUNK?.....UPDATE!! [Re: BSB67] #1893337
08/17/15 12:35 AM
08/17/15 12:35 AM
I have the small passage 440 Source water pump housing on my 500 in. motor. Runs cool as a cucumber.
I like hearing that! & you want no less than a 180 stat in there to get the eng above that cold/high wear window AS FAST as possible. Yes you are getting above 180 (with time) but you wanna be there ASAP & you get that with the stat being closed
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: strokerchall] #1893360
08/17/15 12:59 AM
08/17/15 12:59 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Boiling point of water is 212°
With the correct radiator cap and antifreeze, it is like 240°
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: BSB67] #1893416
08/17/15 02:44 AM
08/17/15 02:44 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
^^^ and the 165 stat is open all the time once warmed up. Coolant has no time to lose heat passing right through the radiator. He might find a 195 could hold it right around the number.
I want my fair share
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: SomeCarGuy] #1893444
08/17/15 05:23 AM
08/17/15 05:23 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
There's that myth again.
If so, then why would the same coolant have enough time in the engine to take up all the heat?
If a 165 stat is used and temps still rise above that all the time, it simply means the radiator/coolingsystem is not up to the task of cooling the engine, or the engine is not running efficiently enough.
Re: 440SOURCE WATER PUMP HOUSING....JUNK? [Re: BigBlockMopar] #1894028
08/17/15 11:24 PM
08/17/15 11:24 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
He is running the same water pump..
Just my $0.02... wink
Re: 440SOURCE WATER PUMP HOUSING....JUNK?.....UPDATE!! [Re: BSB67] #1894031
08/17/15 11:27 PM
08/17/15 11:27 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
But whats the average temperature in Prospect, PA?
Today in SoCal it hit 109 degrees..
Re: 440SOURCE WATER PUMP HOUSING....JUNK?.....UPDATE!! [Re: strokerchall] #1894075
08/18/15 12:29 AM
08/18/15 12:29 AM
Uranus
Uranus
its an 07 housing,so i think its the one with the restriction prob
Re: 440SOURCE WATER PUMP HOUSING....JUNK?.....UPDATE!! [Re: Sinitro] #1894125
08/18/15 01:53 AM
08/18/15 01:53 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The average temp in Prospect Pa is not 109°F, nor is it in So Cal. The car runs fine in the low 90°s, but I prefer to not drive it when it is that hot.
So the overheating only occurs at over 100°?
