Re: 1969 small block water pump to a 360 will it work
[Re: Rhinodart]
#1894106
08/18/15 01:26 AM
08/18/15 01:26 AM
RapidRobert
the 69 iron pump is shallower so you'll need a spacer to move the fan forward (no big deal) to where it was with the alum pump. Check bolt length & use spacers/shorter bolts as needed to duplicate what you originally had (good precaution/use Permatex #2). the rad hose/nipple and timing marks will be (both) on the DR side but you can see the marks if you aim the light just right (or find exact TDC & make a pointer for the pass side. Some paint marks on the DR side tab for 0-10-15-17-20 helps with this & some paint marks on the dampener if you use a pointer on the pass side. 0.0632683" around the dampener circumference is (1) degree (cut/measure a strip of white paper)
[Re: Dart6pak]
#1894234
08/18/15 10:24 AM
08/18/15 10:24 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
YOu need to run the timing cover too. There is on bolt hole difference between the old and new style covers. I think the newer block has the hole and the older cover doesn't, been a few years since I did this so double check when fitting up the cover. If that hole is there and is not plugged it will leak coolant, BTDT.
[Re: Supercuda]
#1894338
08/18/15 01:20 PM
08/18/15 01:20 PM
RapidRobert
You can get by with just changing the pump which keeps the tcover/block hole orientation as is & functioning but it causes a slight aforementioned prob reading the timing marks. If this was a permanent deal then yes I would want to swap covers & remark the dampener to match and there was a bolt on tab on some 60's SB's (they're available used) that went on the pass side (I have one) & if it bolts onto the late tcover that'd take care of the dampener markings other than a white paint mark for TDC
