Wandering front end. #1893292
08/16/15 11:52 PM
08/16/15 11:52 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Just rebuilt the front end in my 77 D-100. Had the front end aligned and it still wanders some. I replaced all balljoints, upper and lower control arm bushings, inner and outer tierods and idler arm. I figured once aligned it would roll straight. Should I use a different front end shop?
Re: Wandering front end. [Re: elmor353] #1893336
08/17/15 12:33 AM
08/17/15 12:33 AM
and it ain't a slipped belt tire problem? always wandered? I'd call the shop & confirm they got it right. tire prob/bent frame/wrong alignment/ bent something. Holler how it goes
Re: Wandering front end. [Re: RapidRobert] #1893343
08/17/15 12:41 AM
08/17/15 12:41 AM
ND
dodgedon Offline
dodgedon  Offline
ND
What about the steering coupler? Where the column meets the box...
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Wandering front end. [Re: elmor353] #1893355
08/17/15 12:54 AM
08/17/15 12:54 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How about play in the steering box?
Re: Wandering front end. [Re: elmor353] #1893418
08/17/15 02:46 AM
08/17/15 02:46 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Pitman?
I want my fair share
Re: Wandering front end. [Re: elmor353] #1893488
08/17/15 11:14 AM
08/17/15 11:14 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
What RapidRobert asked; did it wander before the work was done?
Facts are stubborn things.
Re: Wandering front end. [Re: elmor353] #1893759
08/17/15 06:55 PM
08/17/15 06:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What kind of tires? Bias plies tend to wander more than radials, especially on raids with rain grooves or ruts.
Don't be the exception.
Re: Wandering front end. [Re: elmor353] #1893784
08/17/15 07:20 PM
08/17/15 07:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
How much positive caster were they able to get? I bet not much if any positive I'm thinking?
If so more positive caster really helps, are off set upper control arm bushings available for your truck? Did you use and install them correctly?
Re: Wandering front end. [Re: elmor353] #1894216
08/18/15 09:52 AM
08/18/15 09:52 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Assuming it didn't wander before, and everything else are the same parts (steering gear/coupler, etc.) then I agree that alignment is likely the issue. I had this same problem on my '80 Aspen. A second trip to alignment shop helped, but I am looking for another shop that has someone who knows how to align an old Mopar.
Bad or loose wheel bearings can cause wander too. Maybe check the nut to confirm proper tightening. Easy and free.
