67 cuda dash frame color and texture?
#1885683
08/05/15 04:07 PM
08/05/15 04:07 PM
Posts: 5,664 South Dakota
hotairballoonpilot
South Dakota
The red on a metal dash of a 67 cuda. What was or is used?
thanks corey
Contact Me about AMD Prices
Re: 67 cuda dash frame color and texture?
[Re: hotairballoonpilot]
#1919615
09/25/15 05:42 PM
09/25/15 05:42 PM
hotairballoonpilot
South Dakota
Wondering what it might look like if we do the dash the same color as door areas & 1/4 trim areas but only in a satin finish? The dash panel was not the same color of the actual metallic red on the doors. Car is not getting a true factory restoration in that the customer will be putting a 360 that was in the car when he bought it. Car will be solid red on the outside along with white interior from legendary. what are the views?
[Re: autoxcuda]
#1921152
09/28/15 01:00 PM
09/28/15 01:00 PM
hotairballoonpilot
South Dakota
So is the steering column the same suede texture as the dash frame? I was able to locate the 68 red but its a little darker than the original was so I am getting my jobber to tint it closer. Column does feed like it was textured before though.
corey
