m63 hv oil pump clearances and modifications?? #189256
01/10/09 08:46 AM
01/10/09 08:46 AM
Ohio
fiddlestix Offline OP
Ohio
Can anyone tell me where to find the proper clearance dimensions for a Melling m63hv oil pump and if there are any other modifications I should make to it? I have read the page in the tech archives about this pump already.
Thanks guys
Re: m63 hv oil pump clearances and modifications?? [Re: fiddlestix] #189257
01/10/09 11:43 AM
01/10/09 11:43 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I don't know what the proper clearance dimensions are but would guess that they would be that same as those in the service manual.
I think that there is something in the tech archives on oil pumps mods, or tuning.
What I found on the last three new Melling pumps (standard rotor) is a very poor alingment between the body and head pressurized oil passage at the o-ring. They were bad enough that I enlarged the mounting holes and drilled for roll pins after fixing the alignment problem. I then ream the oil passage in the pump body to better match the hole size in the pump head. I don't know if anyone has seen this in the HV units.
