Let's do speedo and rear gear math! #1892306
08/15/15 11:14 AM
08/15/15 11:14 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Here we go. I have a 1964 Dodge that has a '63 Big block 727 transmission. The rear end has been updated with 3:73 gears. Rear tire diameter is 26.5". Picture attached is from 63 service manual. Need to know what diameter an original 700 X 14 tire would be and which gear to use, to get speedo close. I have had NO luck trying to get a ratio adapter for this car. The output shaft has 8 teeth. Need to factor in the difference in tire size and no correct choice for the new gear ratio. Thanks!
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1892322
08/15/15 11:51 AM
08/15/15 11:51 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Approximately 205/70/14 25.30 diameter.
Chris from New Jersey
Re: Let's do speedo and rear gear math! [Re: fig426] #1892373
08/15/15 01:23 PM
08/15/15 01:23 PM
What I'd do is get the exact dia from "rollout" then go to the MP chart. then you'd have your dia and 3.73 ratio. someone here posted the chart that goes to the tenths of tooth count, I'd find it or see if someone will repost it. IE if says you need a 26.2 tooth pinion for your dia then find a 26 tooth pinion and if you need a 26.7 tooth pinion then find a 27 tooth pinion & if you have an early trans then yes you'll likely need the adapter
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1892376
08/15/15 01:31 PM
08/15/15 01:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You cannot use later pinion math for early pinion choices. The number of teeth on the output shaft is different and will throw the math off if you try to extrapolate from later pinion calculators.
Don't be the exception.
Re: Let's do speedo and rear gear math! [Re: Supercuda] #1892395
08/15/15 01:50 PM
08/15/15 01:50 PM
good clarification. OP, with that early trans & pinion selection being limited (as you know) you might try evilbay or the guys at www.slantsix.org or FABO and somebody has to be selling those adapters
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1892397
08/15/15 01:54 PM
08/15/15 01:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You shouldn't have a problem getting a ratio adapter,
http://imperialservices.net/Bparts.html
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1892503
08/15/15 05:36 PM
08/15/15 05:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You'd need a 23-tooth pinion and there ain't no such thing. There are inline ratio adapters that can be installed in the speedo cable.
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1894107
08/18/15 01:27 AM
08/18/15 01:27 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
I have tried to contact Imperial Services without much luck. I'll keep everyone posted...
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1900396
08/27/15 02:08 PM
08/27/15 02:08 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Imperial Services has been sold, all in transition now. Today I talked to the new owner and a ratio adapter for this car is coming, 4-6 weeks out. Built to the .67 reduction ratio required!
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1900441
08/27/15 03:17 PM
08/27/15 03:17 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
how did someone figure .67 ratio reducer? what pinion are you using now? i don't think the math is right.
Re: Let's do speedo and rear gear math! [Re: lewtot184] #1900458
08/27/15 03:45 PM
08/27/15 03:45 PM
dogdays Offline
dogdays  Offline
A 700 x 14 tire should be about 25.5 inches diameter
R.
Re: Let's do speedo and rear gear math! [Re: lewtot184] #1900773
08/28/15 12:10 AM
08/28/15 12:10 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Here's what we did. Drove the car with a GPS showing the actual speed. At actual 40 mph, speedometer reads 60. At 50 mph speedo reads 75, and at actual speed of 60 mph speedo reads 90. In each example, divide the actual mph by the reading of the speedometer. In this case, it works out to a .67 reduction to match the speedometer to the GPS. Having a ratio reducer built since there is no factory gear available to correct the difference.
This is an early (63 BB 727) transmission. They are different from the '66 up units. Has an 8 tooth drive gear and a 16 tooth gear on cable now, car updated with 3:73 rear gear and tire at 26.5" diameter. This should work. It may be a little pricey, but they are the only game in town for the 62-65 trans.
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1900882
08/28/15 03:17 AM
08/28/15 03:17 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Ran into the same problem with a 63 Sport Fury running a 65 BB trans with a 64 valve body. Car has 3.91s
Just got the biggest gear I could get. Damn was it pricey
Re: Let's do speedo and rear gear math! [Re: lewtot184] #1901174
08/28/15 04:11 PM
08/28/15 04:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Small tires and high (numeric) axle ratios generate speedo cable speeds that can't be corrected with the available 16-21 tooth early pinions. The .67 reduction allows the user to alter the normal math to choose the correct pinion.
As I stated earlier, the OP's combo would require a 23-tooth pinion which was never available so the .67 reduction would call for a 15-tooth pinion which, also, was never available; so a 16-tooth would be the closest.
That's why an inline reducer is more practical, they allow for a wide variety of reduction ratios.
Re: Let's do speedo and rear gear math! [Re: John_Kunkel] #1901178
08/28/15 04:15 PM
08/28/15 04:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
john, i'm very familiar with the ratio reducers. i use one in my '65 coronet. it just seems to me that .67 is very steep, even with a 16 or 17 tooth pinion.
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1901182
08/28/15 04:23 PM
08/28/15 04:23 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i'll assume the 16 tooth pinion was with a 2.76 rear gear. 2.76 divided by 3.73 (new gear) is .74. my take is a .74% reduction. o'well, what do i know?
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1901495
08/28/15 11:25 PM
08/28/15 11:25 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Well, doing math with the GPS and the speedometer, this takes the actual rear tire size into the formula. You don't even have to figure it in, which is what you may be missing with the .74 (2:76 + 3:73) number. The difference between the orig 7.00 X 14 versus the new diameter tire. These were the readings driving the car:
GPS mph divided by speedometer reading = reduction required
40 divided by 60 = .66666667
50 divided by 75 = .66666667
60 divided by 90 = .66666667
.67 should put it spot on...
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1901728
08/29/15 10:42 AM
08/29/15 10:42 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i trust the math, not the gps.
Re: Let's do speedo and rear gear math! [Re: lewtot184] #1901766
08/29/15 11:53 AM
08/29/15 11:53 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you show your math?
Re: Let's do speedo and rear gear math! [Re: lewtot184] #1901960
08/29/15 06:20 PM
08/29/15 06:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Problem is, the math only guarantees an accurate odometer not an accurate speedometer. Many speedo errors are in the head itself.
