8-3/4 pinion seal part number #1892344
08/15/15 12:30 PM
08/15/15 12:30 PM
Youngsville, NC
dem440c Offline OP
dem440c  Offline OP
Youngsville, NC
I have a 742 case that I thought came out of a 1967 New Yorker. Maybe it came from something else. The pinion seal was bad so I looked up 1967 NYer and it gave me part number 8515N, but when that arrived it is too small. I tried to look it up a couple of different ways but having trouble finding a resource that tells me the application AND the measurements.
8515N has an OD of approx 2-7/8"
from measuring the opening of the case, I think I need a seal with an OD of approx 3-1/8"
Anyone got the info or can point me in the right direction?
Re: 8-3/4 pinion seal part number [Re: dem440c] #1892357
08/15/15 12:57 PM
08/15/15 12:57 PM
Crofton, MD
bri440 Offline
bri440  Offline
Crofton, MD
Went through the same issue myself. Many of the websites/catalogues are wrong. Mancini's or O'Riely's has the correct part numbers. If I remember there were three different seal numbers that matched to a 8-3/4 rear. I believe O'Riely's even had the dimensions of the seal to double check.
Good Luck,
Re: 8-3/4 pinion seal part number [Re: dem440c] #1892359
08/15/15 01:07 PM
08/15/15 01:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Rockauto lists them by casting number, the 8515N you have is for a 741 casting. 7216 is for a 742 casting
Don't be the exception.
Re: 8-3/4 pinion seal part number [Re: dem440c] #1892506
08/15/15 05:46 PM
08/15/15 05:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 8-3/4 pinion seal part number [Re: dem440c] #1892770
08/16/15 01:48 AM
08/16/15 01:48 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Dr. Diff has what you need and he's a member here. Nice dude.
http://www.doctordiff.com/8-3-4-pinion-seal.html
I’m listening.
