Re: Best Brake setup for 15" wheels
[Re: BigBlockMopar]
#1890933
08/13/15 12:32 PM
08/13/15 12:32 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I've heard (from a particular source) that the C-body cast iron factory calipers give greater clamping force, thus better potential stopping power, as compared to aftermarket aluminum calipers (ie: Wilwood in particular). This pertains to the 11.75 factory C-body rotor swap. Anyone here ever try different calipers with the 11.75 rotors... and could tell any noticeable difference (assuming similar type of pads)?
Eventually I'll swap to the 11.75 rotors so that I can still run my 15" vintage minilite rims (for street/hwy).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: BigBlockMopar]
#1891858
08/14/15 02:50 PM
08/14/15 02:50 PM
Mopar Mitch
BBM --- yes, the diameter of the pistons was the main issue that was said to be the differing factor.
I don't know how much it really makes any difference.... say from using the Wilwoods with the adapters avlbl from AREng'g.
Mopar Mitch
[Re: BergmanAutoCraft]
#1891864
08/14/15 02:56 PM
08/14/15 02:56 PM
Mopar Mitch
Peter... I'd actually prefer to use the Viper calipers (thus, keeping it MOPAR), although they are apparently increasingly difficult to find. Also, they are rather large... concerns me IF they'd fit within my 15" cast aluminum minilite rims... wish I could eventually try them on someone's car who has them.
Its not a big hurry or high priority for me... will do eventually.
Mopar Mitch
[Re: DoctorDiff]
#1893549
08/17/15 01:46 PM
08/17/15 01:46 PM
Posts: 4,452 Michigan
MarkZ
Worthy
Worthy
First generation Viper calipers are common on eBay. The calipers are, but what about the adapters? I thought the only ones still being produced are for drum spindles.
[Re: DoctorDiff]
#1895028
08/19/15 12:50 AM
08/19/15 12:50 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
First generation Viper calipers are common on eBay. Do you still sell the kit? They've been out of stock on your website for as long as I can remember.
[Re: MarkZ]
#1895531
08/19/15 07:10 PM
08/19/15 07:10 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
First generation Viper calipers are common on eBay. The calipers are, but what about the adapters? I thought the only ones still being produced are for drum spindles. I've got a set of them sitting on my mill at the moment. I could be convinced to build another set. Or two. Or three. ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: OLD318]
#1895587
08/19/15 08:29 PM
08/19/15 08:29 PM
feets
Senior Management
Senior Management
Irving, TX
There is some messy stuff going on here.
Brake pressure differs between calipers. However, a properly matched master cylinder will fix that problem.
Don't like the pressure with the Viper calipers? Get the properly sized master cylinder. If you need to remove a 1/2" nut you don't reach for a 9/16" wrench. It won't work right. Instead, you use the proper size tool for the job. The same goes with the brakes.
The early C body (and pre-85 D150/B150) rotor is 1-1/4" thick. That's a good fit for the Viper caliper. Unfortunately, the outer wheel bearing is different. The inners are the same. A little searching might find you the proper outer bearing or a spindle liner to give you the extra .030" needed for a proper fit.
Keep in mind that the fixed calipers (like the Viper pieces) are VERY wide. So wide, in fact, that they can hit the back of the wheel before the wheel touches the hub. Careful measurements must be made.
The D150/B150/C-body calipers are the same. I do not know if they fit the pin brackets used on B-bodies. If so, that would be the cheapest effective brake package for the 15" wheels. The pads are the same so you need to look at the offset of the bracket itself.
Brakes turn kinetic energy into heat. Excessive heat kills brakes. The fatter brake rotors take longer to heat up and have a better chance of releasing the heat into the atmosphere. They're 5 lbs heavier than the B-body pieces. Much of that is in the braking surfaces. A high performance pad (assuming they are available) would work wonders. The pads are the same for the D150/B150/C-bodies.
[Re: feets]
#1895840
08/20/15 11:30 AM
08/20/15 11:30 AM
MarkZ
Worthy
Worthy
First generation Viper calipers are common on eBay. The calipers are, but what about the adapters? I thought the only ones still being produced are for drum spindles. I've got a set of them sitting on my mill at the moment. I could be convinced to build another set. Or two. Or three. The adapters to mount generation 1 Viper calipers to 73+ disk brake spindles on 11.75" rotors? ![](http://blog.theregularguynyc.com/wp-content/uploads/2013/08/shut-up-and-take-my-money.jpg)
[Re: MarkZ]
#1895982
08/20/15 03:46 PM
08/20/15 03:46 PM
feets
Senior Management
Senior Management
Irving, TX
Viper calipers on B-body rotors will require a spacer behind the brake pads. Viper calipers on C-body/D150/B150 rotors will require a different outer bearing. I haven't dug around to see if the bearing exists or if a spindle sleeve will be required. Either set will require careful measuring to be sure the caliper will not contact the wheel. I think Dr Diff bailed on this application due to low sales. Building the parts isn't hard, it just takes a little time on manual machines. I've done more challenging conversions. ![](http://image.hotrod.com/f/9166458+q80+re0+cr1+ar0/0711phr_07_z%2b1965_plymouth_belvedere%2bwheel.jpg)
[Re: BigBlockMopar]
#1896140
08/20/15 07:57 PM
08/20/15 07:57 PM
feets
Senior Management
Senior Management
Irving, TX
The outer wheel bearing on a B-body has a .750" inside diameter. The outer wheel bearing on a C-body has a .866" inside diameter.
Not a good mix for a steering axle.
