Page 2 of 3 1 2 3
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1890521
08/12/15 08:47 PM
08/12/15 08:47 PM
California
mickm Offline
mickm  Offline
California
Originally Posted By Black_Bee
Hey guys
I drained the oil and dumped it back through the valley three times and didn't find the washer in the pan with a magnet.
After doing that, I crawled back under the car last night with the intention of dropping the pan, but just couldn't bring myself to do it. I know that it could very well come back to haunt me, but I'm just gonna leave it in there.
Thanks for the advice guys!
definitely understand that sentiment! good luck with it! up
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1890537
08/12/15 08:58 PM
08/12/15 08:58 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Not going to hurt a thing unless it's pulled up the pickup and gets into the oil pump, I've seen the presser relief valve stick wide open as a result of junk going thru the pump. Zero oil pressure!
Have a great day
Iowan
"obsolete is neat"
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1890625
08/12/15 11:01 PM
08/12/15 11:01 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Hey guys
Bubba fix: get one of dem der magnetic drain plugs from Wally World. Splashing around in der, you might land dat sucker where It can't do no damage. Not likely to anyhow, that's what the pump screen is there for.
You might check out this magnet, perhaps even fetch the washer from top side where it fell in.
http://www.amazon.com/gp/product/B000H5Q...ailpage_o09_s00
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1890632
08/12/15 11:10 PM
08/12/15 11:10 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Are you absolutely positively saw it with your own eyes sure that it did not go down an intake port instead of down past the cam?
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1890792
08/13/15 03:03 AM
08/13/15 03:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Everyone telling you to just run it aren't the ones that will have to deal with the aftermath.
I work in confined spaces with hi voltage ... 50kvdc ... if I dropped something like that I don't leave till I find it ... and I find it.
fan
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1890835
08/13/15 08:56 AM
08/13/15 08:56 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
And what is the projected aftermath of leaving it there?
It's too small to damage the bottom end, too big to sucked into the oil pump.
If it ended up in an intake port there's only a 12% chance it went into a cylinder.
Angry white pureblood male
Re: Dropped a tiny lock washer into open engine [Re: JohnRR] #1890855
08/13/15 10:02 AM
08/13/15 10:02 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
fan
iagree iagree iagree
Like I said in my first post, you need to dump something like gas or kerosene into the valley to wash it down into the sump. The oil you dumped in is too thick and won't move that washer if it's laying on the windage tray's oil film.
If that doesn't work, drop the pan and find it.
If you are determined to leave it in there and run it, atleast get a magnetic drain plug so if/when it does make it to the sump, hopefully it'll stick to it and stay put. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1890858
08/13/15 10:11 AM
08/13/15 10:11 AM
Up a holler, down a crick
booger Offline
booger  Offline
Way back in the mid-70s I dropped a small washer with the distributor out and it went right down the hole and gone.
Every now and again I'd think I heard it tink-tink-tink as it slung around in there but it was probably just my imagination.
That was a little different case, because mine went right down the front of the engine, not into the heart of things.
I was about 17 at the time. Today I'd probably tear it down to find it or it would drive me nuts worrying about it.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1891061
08/13/15 03:42 PM
08/13/15 03:42 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd tear it down. My name should've been Murphy because anything that can happen will happen to me. I don't have the golden touch that some seem to have.
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1891099
08/13/15 04:46 PM
08/13/15 04:46 PM
BC, Canada
Black_Bee Offline OP
BC, Canada
Hey guys
I just keep coming back to the question... "what damage could this washer actually cause?" Its a serious question, and not me thinking that it couldn't do any damage.
After dropping it in there (it definitely didn't go into the intake port) chances are it landed on the rotating assembly. I have now cranked the engine over (not started it), and chances are it has been flung down to the windage tray. Obviously buzzing an engine up to say 6500 RPM will make a serious whirlwind of oil and it could move the washer all around inside the engine, but what damage could it do? I think that its too big to get at any bearings or get under a piston skirt, or get sucked up by the pump. I guess it could get flung up to the cam and cause damage like that?
Thanks for the continued advice/support here guys... just so you know where my indecisiveness is coming from, I am at the end of a seriously long project on the car (like 6 months of evenings and weekends) and honestly I am simply sick of working on the car and just want to finish what is required and drive it.
Paul
'69 Super Bee 383 EFI Turbo
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1891100
08/13/15 04:49 PM
08/13/15 04:49 PM
You've been working on it for 6 months already...what's another couple hours to drop the pan and get the washer out?
CHIP
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1891106
08/13/15 04:52 PM
08/13/15 04:52 PM
California
mickm Offline
mickm  Offline
California
this is a tough one, i know. believe me, i know well the feeling of having been at it so long, and just not having the motivation to do this. i'm about to tear my transmission out for a problem that i've been chasing for years, never find any evidence of the problem, put it back together and it runs fine, for a while.
anyway, i think the only real issue is to make a firm decision that
a) you are willing to deal with the consequences if this goes wrong, (in which case i would write that decision down on a piece of paper so you can look at it later when, if something does go wrong, you are tempted to kick yourself in a$$ for making that decision)
b) you suck it up and tear it apart.
i understand eiher way, and would be tempted to take option a. you just have to be sure you are willing to live with the possible consequences.
Re: Dropped a tiny lock washer into open engine [Re: mickm] #1891107
08/13/15 04:54 PM
08/13/15 04:54 PM
California
mickm Offline
mickm  Offline
California
oh, and if you decide to tear it apart, get new pan gaskets from superformance. i have them on my pan now, and they are fantastic! no leaks, and only a very small bead of gasket sealer on the top gasket to the pan rail. if i have to take the pan off again, it will be a piece of cake!
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1891111
08/13/15 04:56 PM
08/13/15 04:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Bingo!!! Much ado about nothing. Even if it does miraculously get picked up by the rotating assembly, after a couple of bounces it'll wind up in the pan where the pickup screen will stop its movement.
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1891453
08/13/15 11:34 PM
08/13/15 11:34 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Just put a magnet on the bottom of the oil pan and leave it there. When the washer makes it's way there the magnet will hold it through the pan and keep it there. That way it won't be moving around .
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1891490
08/14/15 12:28 AM
08/14/15 12:28 AM
is this a new cam (and or ring) breakin? too much cranking would concern me more than the washer, just sayin
Re: Dropped a tiny lock washer into open engine [Re: RapidRobert] #1891541
08/14/15 01:39 AM
08/14/15 01:39 AM
BC, Canada
BC, Canada
No... engine is not a new build. I just meant that I hadnt started it since dropping the washer in it.
beer
Paul
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1891590
08/14/15 03:23 AM
08/14/15 03:23 AM
Alright, good deal
Re: Dropped a tiny lock washer into open engine [Re: RapidRobert] #1891678
08/14/15 10:18 AM
08/14/15 10:18 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'd lift the motor after unhooking the mounts, then remove the pan to look. If I didn't find it, I wouldn't be able to sleep at night until I pulled the engine and found it.
4 hours to pull the engine, a few hours to start removing the bottom end until you find it, begin reassembly, and 4 hours to put it back together. You're talking a weekend. one single weekend. vs the potential that something bad happens and you're out several weekends as you pull it out, tear it down, machine costs, new parts costs, time to rebuild, etc.
**Photobucket sucks**
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1891786
08/14/15 12:48 PM
08/14/15 12:48 PM
North Austin
KnuckleDuster Offline
North Austin
I did the same thing with a carb washer. A trusted mechanic friend told me to forget about it.I turned it over by hand to check for binding and ran it. It was in the pan when I swapped to a Kevco 1000 mi later. Unless you roll the car it's not going anywhere.
Page 2 of 3 1 2 3
