push-on window trim/seals
#1890916
08/13/15 12:15 PM
08/13/15 12:15 PM
Posts: 7,506 Az
Crizila
Az
I am looking for some window trim / seals for my glass doors. Have about 7/32" gap between the glass and the door edges (pretty consistent on both sides and all around ). Door edge thickness = 3/32". Any suggestions would be appreciated. Thanks, John
Fastest 300
Re: push-on window trim/seals
[Re: Crizila]
#1897959
08/23/15 10:32 PM
08/23/15 10:32 PM
Posts: 306 Georgia
69bfan
Georgia
Check out Restoration Specialties and Supply in Windber, PA. They will have pretty much everything that you will need. They may already have them made up for this application. Reach them at 814-467-9842. You can also see some of their product online by doing a search.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
