Re: 2001 1500 Front Axle Seals. Job for a Pro?
[Re: buildanother]
#1890947
08/13/15 12:42 PM
08/13/15 12:42 PM
Posts: 3,078 N.W. Florida
Fat_Mike
N.W. Florida
I didn't specify, but the part I'm worried about is making sure I don't screw up the backlash (not sure if that's the correct term). This short "how to" link makes it look simple. http://d44tech.com/axle_seals.html My truck has been known to go through shallow creeks during hunting season, so I definitely want to change them (both, while I'm in there). I reckon I'll give it a shot...unless someone here talks me out of it.
[Re: CTD5.9]
#1891177
08/13/15 06:18 PM
08/13/15 06:18 PM
Fat_Mike
N.W. Florida
I just read passenger side, I do believe on the CAD axles you don't even need to remove the carrier for that axle seal. BUT it's a giant PAIN to get it in there because its actually in the axle tube I read that somewhere along the way also...allthread, washers, slide hammer thing. Aside from not wanting to do it that way, I JUST got out from under it to top it off, and noticed the driver's side is also wet. Not nearly as bad as the passenger side, but it's leaking. So...
[Re: Fat_Mike]
#1891842
08/14/15 02:24 PM
08/14/15 02:24 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Fat_Mike: I've had to do this miserable job on this Horses' Ass setup twice on the passenger side. The best advice I can give you, is to pay extra for the seal at a Chrysler Dealer and ask them to loan you the installer tool. The first time I did it I built my own tool by welding the old seal to a nut, threading it on ready-rod and it didn't work. You need their tool because it centers everything and pulls the seal in straight. It's a blind pull so everything has to line up perfect and ready-rod with big washers and nuts won't do it. I took photos last time of their puller and I have a die from a ball-joint installer kit that fits their seal perfect. I will try to build another but this time will spend a day doing it. The seals leaking isn't your fault from doing the u-joints, Mike. There is a trick to re-installing your axles, pm me. If you let the u-joints go too long they vibrate/have too much play and beat the seal up. Then the leak starts. Of course, it doesn't show up until after you get everything back together, happened to me too. I feel your pain: These straight-axle front-ends in these trucks is the worst design I have ever seen in my life. Made to fail, and made to anger the do-it-yourselfer to all ends. What kind of an IDIOT Engineer positions an axle seal six inches inside the tube and makes it so you can't see what you're doing? The kind that has a supervisor telling them to make it so the Customer has to take it to the dealer to do, that's who. I have a solution to fix the whole mess but it's more work than it's worth. Let us know how you make out on the driver-side: I haven't had to do it...........yet. Sorry for the rant, I'm just trying to get a riot going for all the Jeep and HD Owners who continue to have to deal with this mess. *Edit* I have the service manual as a pdf if you need, let me know.
Mo' Farts
Moderated by "tbagger".
[Re: Fat_Mike]
#1892375
08/15/15 01:28 PM
08/15/15 01:28 PM
Posts: 6,003 Salem
Grizzly
Salem
Should be there, let me know if it doesn't go through.
Mo' Farts
