Where do these brake line bolts go? #1889203
08/11/15 12:15 AM
08/11/15 12:15 AM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
I see this brake line set sells for the 66-70 B body.
Where do those three bolts install?
On my fuel line clip set there is the black colored bolt/clip that mounts where the line bends around the rear frame rail (inside the wheel well area). I'm assuming one of these bolts does the same for the driver side rear frame rail?
Re: Where do these brake line bolts go? [Re: fatsat] #1889616
08/11/15 05:49 PM
08/11/15 05:49 PM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
I guess my main question is what's the right attachment that mounts the brake line to the rear frame rail?
On this persons car there is a clip holding the line rather than a bolt/clamp. Is this correct?
Re: Where do these brake line bolts go? [Re: fatsat] #1889981
08/12/15 12:51 AM
08/12/15 12:51 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
Should be a bolt/clamp combo right there.
Re: Where do these brake line bolts go? [Re: fatsat] #1890081
08/12/15 07:27 AM
08/12/15 07:27 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I recently r+r some brake lines on a 69 b body and the pictured spot had a clip. They were the factory lines that came off.
There were no clamps on the brake lines, fuel line had the clamp on the shock cross member but the fuel lines had been monkeyed with.
Angry white pureblood male
Re: Where do these brake line bolts go? [Re: fatsat] #1890662
08/12/15 11:39 PM
08/12/15 11:39 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Here's where another one goes if your brake line goes under the frame. Some models stay on top of the rail.
