05 Durango oil light - beep alarm #1889920
08/11/15 11:34 PM
08/11/15 11:34 PM
michigan
440whiteboy Offline OP
michigan
2005 Durango 4 x 4 awd - 4.7 engine 137,000 miles
my oil light is on all the time, after it warms up - then the beep alarm goes crazy - a zillion times - wont turn off...
took her in for another oil change in hope to stop it.
took it to autozone to do ub2 check - they say the computer is not communicating?
maybe a sensor?
any idea's?
thanks in advance -
They only see Stars...
when hit by a Mopar!
Re: 05 Durango oil light - beep alarm [Re: 440whiteboy] #1890021
08/12/15 01:40 AM
08/12/15 01:40 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the engine isn't rattling replace the sending unit it's cheap enough.
Re: 05 Durango oil light - beep alarm [Re: stumpy] #1892739
08/16/15 12:59 AM
08/16/15 12:59 AM
Lowes
steve660 Offline
steve660  Offline
Lowes
Same problem on 2010 Avenger with 2.4 engine.
Changed sensor....still beeps and oil light still on.
Plumbed in a Tee fitting between block and sensor for oil gauge.
On cold startup has 60PSI oil pressure ...still beeps and oil light still on.
Increase RPM over 1500 and beeping stops and light goes out.
Return to idle speed and oil light comes back on and starts beeping.
Now what???? WTH!!!!!
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
