Re: Need help diagnosing pop in freshly rebuilt front end 71RR
[Re: TJP]
#1889280
08/11/15 02:13 AM
08/11/15 02:13 AM
RapidRobert
Double check all fasteners, bolt's etc..
that'd be my start. was the suspension loaded (at ride height when the bushings etc were finally tightened. As you know something is loose/moving when under stress
[Re: RapidRobert]
#1889795
08/11/15 09:46 PM
08/11/15 09:46 PM
Posts: 1,106 michigan
440whiteboy
michigan
also look at your castle nut under tie rod or linkage arm? I thought I had mine tight enough, finding it was way loose after. just a thought -
They only see Stars... when hit by a Mopar!
[Re: JonC]
#1889939
08/11/15 11:54 PM
08/11/15 11:54 PM
Posts: 129 Springfield, MO
Steve88
Springfield, MO
Did you grease the torsion bar ends? Thanks everyone for the replies! I am not sure that I greased the torsion bar ends. What parts of the torsion bars need to be greased? Thanks
[Re: Steve88]
#1890011
08/12/15 01:19 AM
08/12/15 01:19 AM
RapidRobert
no cuz they fit into the matching hex recesses pretty tight. EDIT If you do undo em be sure to measure the ride height on each side before so you can get it back to that exact height so as to not alter your alignment specs
[Re: Steve88]
#1891491
08/14/15 12:33 AM
08/14/15 12:33 AM
RapidRobert
You might shoot some WD40 in the hexes just to see if it quiets em, likely would not last forever but that'd confirm that it is the tbars as it'd be better than tearing em down/greasing & then them not being it but there is a good chance it is them but I'd sure give it a shot. EDIT if you do undo em dont forget to duplicate the ride height exactly so you dont mess up your alignment
[Re: Steve88]
#1892244
08/15/15 02:35 AM
08/15/15 02:35 AM
Steve88
Springfield, MO
I pulled the torsion bars and greased them last night but the popping noise is still there. I had a buddy come over today and turn the steering wheel so I could observe the steering linkage in action but I did not see anything out of the ordinary. I watched the steering shaft and steering box while he turned the steering wheel and I did notice the steering box input shaft moved in and out as it was rotated back in forth. The link to the video below shows the input shaft movement. The back and forth movement shown in the video is the slack in the steering box which is almost a 1/2 turn of the wheel before the pitman arm moves either direction. What is your opinion on the input shaft movement? Thanks https://youtu.be/VUug7GxpSlI
[Re: Steve88]
#1892255
08/15/15 03:35 AM
08/15/15 03:35 AM
RapidRobert
What is your opinion on the input shaft movement? I think we've ID'd the problem.
[Re: AARCONV]
#1892444
08/15/15 03:29 PM
08/15/15 03:29 PM
Steve88
Springfield, MO
Check for cracks around where the k frame mounts to I will double check the K member mounts but the car does has a Bob's Profab K member that I recently installed so hopefully they will be ok.
[Re: TJP]
#1892471
08/15/15 04:23 PM
08/15/15 04:23 PM
Steve88
Springfield, MO
Repeat the test with the wheels on the ground and the motor running as the hydraulic pressure may eliminate the end play. IF not time for a steering box. I tried the same test with the engine running and end the play is definitely less with the hydraulic power applied. Could I get someone with a power steering box to try the same test without thier car running to see if they get similar results from the steering box input shaft? It would be just moving the steering wheel back and forth a little without thier car running and observing the input shaft to the steering box. Thanks
[Re: Steve88]
#1893068
08/16/15 06:03 PM
08/16/15 06:03 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Did you contact Bob's to see if they have any feedback on their systems doing this? Might be a commonly overlooked item.
[Re: Steve88]
#1893106
08/16/15 07:02 PM
08/16/15 07:02 PM
Posts: 5,830 ohio
ruderunner
ohio
Look closely at any parts that are bolted together, you're looking for shiny spots or chipped paint that indicates a part shifting around. You may need brighyt lights and a magnifying glass.
Angry white pureblood male
[Re: Steve88]
#1893133
08/16/15 07:34 PM
08/16/15 07:34 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I see you have a lot of aftermarket front end parts, but state you torqued everything according to the service manual. perhaps some/all of these parts have different toque values than stock, and something isn't tight enough, or to tight, causing binding?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Steve88]
#1893188
08/16/15 09:31 PM
08/16/15 09:31 PM
Posts: 1,894 Harriman NY
71GTX471
Harriman NY
Retorque the aftermarket K frame.Find an auto tech with a set of chassis ears & go noise hunting.
[Re: Steve88]
#1893347
08/17/15 12:44 AM
08/17/15 12:44 AM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
Please correct me if I am wrong but the Bobsprofab k members that I have seen have r&p steering, coil over shocks and are intended for light weight race cars. Perhaps you have an Altercation k member instead.
[Re: GomangoCuda]
#1893475
08/17/15 10:50 AM
08/17/15 10:50 AM
Steve88
Springfield, MO
Please correct me if I am wrong but the Bobsprofab k members that I have seen have r&p steering, coil over shocks and are intended for light weight race cars. Perhaps you have an Altercation k member instead. I think Bob's Profab makes a couple different K members or at least did in the past. This one is few years old but takes all of the stock stuff except for a stock style swaybar. I went out last night and double checked everything and made sure that everything is tight. I drove the car in front of my shop some and I did noticed that it is really more of a series of pops rather than just one pop. Going straight everything seems good then a very slight turn to the left I get 2-3 pops right together and same when turning back straight. It does seem to be worse if I turn while backing up. At this point I am open to any idea but I am fairly confident that its not anything being loose because I have checked and double checked all the fastners a couple of times. I can get an occasional pop out of it in my shop but its hard to duplicate the problem when not driving. With the the front wheels off the ground there is no issues at all. With the tires on the ground I get a pop occasionaly with the engine running or not. One I start drving it pops each time I turn and is easily duplicated but of course it is hard to see what is going on while drving.
[Re: Steve88]
#1893538
08/17/15 01:07 PM
08/17/15 01:07 PM
RapidRobert
Any possibility the tbars ain't square? (as in horizontle) with that being an aftermarket setup. When it went together did the bars slide in with what appeared to be a good fit?
[Re: Steve88]
#1893565
08/17/15 02:18 PM
08/17/15 02:18 PM
GomangoCuda
It does seem to be worse if I turn while backing up. Strut bar bushings? Are they urethane? If so they can creek and pop, lube them. Check strut bar mounting points on k frame and control arms for cracks.
[Re: GomangoCuda]
#1893631
08/17/15 04:21 PM
08/17/15 04:21 PM
Steve88
Springfield, MO
It does seem to be worse if I turn while backing up. Strut bar bushings? Are they urethane? If so they can creek and pop, lube them. Check strut bar mounting points on k frame and control arms for cracks. The torsion bars seemed to go in ok. Once I got control arms clocked where they needed to be the bars slid right. I have been wondering if there is an issue with the strut rods. I used the stock strut rods with the Moog 7026 bushings. Is there a way I could have installed them incorrectly causing the lower control arm to get in bind? I probably should have went with adjustable strut rods since everything is aftermarket and that would have allowed for some adjustability.
