I have a 71RR that I just completed a full restoration on and it has an annoying pop in the front end. The pop mostly occurs on left turns and seems worse if there is a bump during the left turn. The pop seems to be coming from the driver's side. Everything is new in the front end. It has a Bob's Profab tubular K member, Firm Feel stage 2 steering box, Flaming river tilt steering column, Firm Feel quick ratio steering arms, Moog balljoints and bushings and all new steering linkage parts. I torqued everything in accordance with the service manual. I greased everything on install then after I noticed the pop so everything should be well lubricated. Any ideas what I may have missed or what I should check? Thanks for the help!
