Re: jack stand palcement
[Re: Todd]
#1888920
08/10/15 05:09 PM
08/10/15 05:09 PM
RapidRobert
you might see if you can good a good point of contact at the front kmember bolts for (2) stands there and can put another (5th) stand under the center of the kmember with it up just touching the K as a backup
[Re: mickm]
#1889006
08/10/15 07:17 PM
08/10/15 07:17 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Put them under the lower control arms, that'll raise the body higher and keep the LCA more out of the way. If that is still in the way, then the forwardmost Kmember mounting bolt.
[Re: mickm]
#1889065
08/10/15 09:17 PM
08/10/15 09:17 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I place the front ones under the lower control arms and the rear under the axle housing. Also I use 6 ton jack stands as they can be adjusted higher, plus they have a larger foot print to make them more stable.
[Re: rowin4]
#1889115
08/10/15 10:36 PM
08/10/15 10:36 PM
RapidRobert
Also I use 6 ton jack stands as they can be adjusted higher, plus they have a larger foot print to make them more stable. X2, no downside to that
[Re: D_C]
#1889483
08/11/15 01:56 PM
08/11/15 01:56 PM
RapidRobert
Sometimes, I have used metal drive-on ramps, backward (with the ramp end forward). I use a floor jack to lift beneath the K-Member and place the ramps in position under each tire (as I said) long end forward (toward the front bumper) to be out of the way. Ding ding ding I do believe we have a winna. that would give the most room ever & be the safest
[Re: D_C]
#1889536
08/11/15 03:29 PM
08/11/15 03:29 PM
Posts: 4,179 California
mickm
California
Sometimes, I have used metal drive-on ramps, backward (with the ramp end forward). I use a floor jack to lift beneath the K-Member and place the ramps in position under each tire (as I said) long end forward (toward the front bumper) to be out of the way. yes, i've thought of that and may get some. only minor problem is the angle part of the ramp still gets in the way a bit with moving in and out from underneath the car. still the best solution though...
[Re: thehemikid]
#1889540
08/11/15 03:31 PM
08/11/15 03:31 PM
mickm
California
It's possible with stands ahead of the front axles that the door latches may bind and not latch well. Put'n in a Passon? no, i wish. i'll start another thread on this later when i tear into it, but i've had an issue for years now. sounds like a throwout bearing going bad. take it apart, no physical evidence of what is going on. put it back together, problem gone for 6 months, 9 months, a year... this is the 3rd time it's come about. this time i decided i was going to drive it until it breaks. well... it broke. we'll see, but i'm 99.9% sure whatever broke is in the bell housing. hopefully this weekend i'm going to get the transmission out, and see what is going on. wish me luck!
[Re: mickm]
#1890124
08/12/15 10:13 AM
08/12/15 10:13 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Whatever you do, be sure to have some kind of secondary safety device. When you think about it...at work, OSHA has demanded we have secondary, sometimes even triple safety devices in place to prevent injury. Yet at home, we often ignore these measures "since they're just annoying overly protective measures by an agency trying to justify their existence"
but sometimes, it just makes sense. cinder blocks under the frame rails, or ramps/blocks under the tires, etc. in case you kick out a stand, or knock the stand with the transmission while trying to slide it out from under the car, etc.
Remember the post I made last May. Lost my 51 year old uncle when his truck fell on him. truck was on jack stands for weeks too, so he had to have kicked something, pulled the truck sideways, etc. while laying under the truck.
**Photobucket sucks**
[Re: 70Cuda383]
#1890312
08/12/15 03:33 PM
08/12/15 03:33 PM
mickm
California
Remember the post I made last May. Lost my 51 year old uncle when his truck fell on him. truck was on jack stands for weeks too, so he had to have kicked something, pulled the truck sideways, etc. while laying under the truck. yes, good point. i'll rig up something, it has been on my mind, especially since seeing your post.
[Re: mickm]
#1890428
08/12/15 06:19 PM
08/12/15 06:19 PM
Supercuda
About to go away
About to go away
up yours
I usually stack the tires under the frame rails as a secondary safety catch.
[Re: D_C]
#1890433
08/12/15 06:26 PM
08/12/15 06:26 PM
Posts: 360 Ohio
shorthorse
Ohio
Sometimes, I have used metal drive-on ramps, backward (with the ramp end forward). I use a floor jack to lift beneath the K-Member and place the ramps in position under each tire (as I said) long end forward (toward the front bumper) to be out of the way. That's what we do and it works great. We still have to jack the front up to get the transmission out from underneath the car because the ramps don't get it high enough to clear the bell housing but it's very stable and gives you lots of room.
[Re: mickm]
#1890533
08/12/15 08:54 PM
08/12/15 08:54 PM
Supercuda
About to go away
About to go away
up yours
I flattened one of those metal ramps with my 64 300, after I had already parked on it and got out. Since then, no thank you, I use the plastic ones when I use a ramp.
[Re: thehemikid]
#1890757
08/13/15 01:28 AM
08/13/15 01:28 AM
RapidRobert
After reading this thread I'm wondering if a person cut the tapered area off of the ramp & welded a vertical plate there. big hyd floor jack to get it up into the depressions since you ain't got no ramp. (4) of em & you'd have your height & safety and no peripheral anything to block your movement. I'd start with some heavy duty ramps
