removing rattle can paint from a carb #1888046
08/09/15 02:23 PM
08/09/15 02:23 PM
bethlehem pa
mikemee1331 Offline OP
bethlehem pa
carb runs fine so i don't want to tear it down but the outside has been painted. paint remover brushed on, carb cleaner soak? not exactly sure how to approach this......
Re: removing rattle can paint from a carb [Re: mikemee1331] #1888058
08/09/15 02:39 PM
08/09/15 02:39 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Spray carb cleaner should work fine or Easy Off oven cleaner
Re: removing rattle can paint from a carb [Re: BulletBob] #1888070
08/09/15 02:54 PM
08/09/15 02:54 PM
Easy off will do it but it sure is nasty stuff to work with & I'd avoid it if I could but it might take something that stout. I ain't an auto body guy so I have not dealt with that. Good luck with it Mike
Re: removing rattle can paint from a carb [Re: RapidRobert] #1888076
08/09/15 03:08 PM
08/09/15 03:08 PM
IN
ahy Offline
ahy  Offline
IN
You might try lacquer thinner on a rag + Q tips. Maybe a tooth brush also. That should take it off without affecting sensitive gaskets or seals. Spray on paint remover or gasket remover would certainly do it also but I'd be afraid it would soak into a gasket and mess the carb up... or just run it and be happy it works properly.
Re: removing rattle can paint from a carb [Re: mikemee1331] #1888091
08/09/15 03:33 PM
08/09/15 03:33 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Strip it and dip it...
Re: removing rattle can paint from a carb [Re: Sixpak] #1888153
08/09/15 05:40 PM
08/09/15 05:40 PM
bethlehem pa
bethlehem pa
the mission was too NOT spend the money to tear it down.
thanks guys! i'll try all of the above with the oven cleaner being last.
Re: removing rattle can paint from a carb [Re: mikemee1331] #1888162
08/09/15 06:00 PM
08/09/15 06:00 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Oven cleaner usually contains lye which can easily create spots or 'react' on/with aluminium.
Re: removing rattle can paint from a carb [Re: mikemee1331] #1888166
08/09/15 06:05 PM
08/09/15 06:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Brake clean will sometimes work in the paint isn't baked on.
Re: removing rattle can paint from a carb [Re: mikemee1331] #1888201
08/09/15 07:13 PM
08/09/15 07:13 PM
jersey
Spaceman Spiff Offline
jersey
Gasoline.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: removing rattle can paint from a carb [Re: mikemee1331] #1888582
08/10/15 03:38 AM
08/10/15 03:38 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
try acetone
Re: removing rattle can paint from a carb [Re: mikemee1331] #1888929
08/10/15 05:21 PM
08/10/15 05:21 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Spray on carb cleaner should do it..
When you work on Spaceships for a living, how bad can a workday be?
Re: removing rattle can paint from a carb [Re: mikemee1331] #1888937
08/10/15 05:41 PM
08/10/15 05:41 PM
bethlehem pa
bethlehem pa
thanks guys. i really appreciate the input. i'll start with the carb cleaner (i have it) and work my way through the suggestions. i think the carb cleaner will work with a little elbow grease. maybe the brake cleaner too but i think the paint might be to 'set' for that. the more aggressive suggestions i'll save for last!
Re: removing rattle can paint from a carb [Re: mikemee1331] #1888971
08/10/15 06:20 PM
08/10/15 06:20 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
when someone spray bombs a carb, most likely they get paint in all the little air passages for the carb.
tearing it down and soaking the body in a bucket of carb cleaner is the only way to get it done the right way.
Re: removing rattle can paint from a carb [Re: joelson6] #1888990
08/10/15 06:48 PM
08/10/15 06:48 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
iagree
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: removing rattle can paint from a carb [Re: mikemee1331] #1889031
08/10/15 07:50 PM
08/10/15 07:50 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
If you want it done right you'll eventually strip it and dip it. If you find a better way I'm all ears. I might try and knock the heaviest bit of paint off before I contaminated by dip can with all that paint.
Re: removing rattle can paint from a carb [Re: mikemee1331] #1890592
08/12/15 10:12 PM
08/12/15 10:12 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Coat it with brake fluid, let it sit for a while, spray it off with Chlorinated brake cleaner. Ever drip brake fluid on your fender? Ya...it eats paint. Chlorinated brake cleaner also eats it, so that should about do it.
